VC LFO2 will not sync/retrigger
Page 1 of 1 [14 Posts]
smokestacksproductions
PostPosted: Tue Dec 25, 2012 5:29 pm    Post subject: VC LFO2 will not sync/retrigger Reply with quote  Mark this post and the followings unread
I built the LFO2 and it works great except the sync input seems to have no effect at all. I am using the recommended tranny (BS170), and I have it oriented as shown in the component overlay on the project page. I have the capacitor soldered on the jack as well. where to start troubleshooting?
Cardinen
PostPosted: Thu Dec 27, 2012 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
What's your sync source ??
PostPosted: Thu Dec 27, 2012 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I am using a gate from my midibox seq. This gate works fine for my yusynth adsr's and my yusynth sample and hold clock, so I don't think the gate is the problem... but I'm open to any suggestions!
marfoski
PostPosted: Thu Dec 27, 2012 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's an issue that's been addressed before. See http://electro-music.com/forum/topic-32340.html&highlight=lfo&start=25, notably the post by Thalassa. It's a problem that I have myself and AFAIK it's never been covered in full.
So I think that we need a definitive word of wisdom by Yves, if he will be kind enough to attend.
PostPosted: Fri Dec 28, 2012 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I sent Yusynth a PM yesterday, hopefully we will hear from him soon!
yusynth
PostPosted: Sun Dec 30, 2012 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
What is the level of your trigger signal?
Yves
PostPosted: Sun Dec 30, 2012 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Trigger is 5v
PostPosted: Wed Jan 02, 2013 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am using a 5v trigger, I have also used a 5v gate, neither produces any result. Should I try a different tranny or something? Should I try a different value for the off-board capacitor?
PostPosted: Thu Jan 03, 2013 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have this working properly?
yusynth
PostPosted: Thu Jan 03, 2013 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try with a 10V GATE signal.
Yves
PostPosted: Thu Jan 24, 2013 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE!
I got it working, with 5v triggers actually, It started working after I installed a new power supply i built based on LM337/317 (my old one was base on 7915/7815)
This new power supply also fixed my problem of latch-up with the VCO's
I am so very happy with my YUSYNTH system and it's almost done!
Thanks so much!
yusynth
PostPosted: Thu Jan 24, 2013 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably you were drawing more power that could provide the 78xx/79xx...
Yves
rizoma
PostPosted: Mon Aug 18, 2014 12:31 pm    Post subject: vclfo2 sync Reply with quote  Mark this post and the followings unread
Hi I built a lfo2 and the sync seems to work, just one question: the sync is suppose to work as reset? I'm not sure if the current behavior is correct.
Regards
yusynth
PostPosted: Sat Aug 30, 2014 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it gives a reset
Yves
