PCB offer: Thomas Henry's Controller LFO
Page 3 of 4 [80 Posts]
Jaba
PostPosted: Thu Mar 07, 2013 7:18 am    Post subject: 2n5461 Reply with quote  Mark this post and the followings unread
Hi LektroiD,
I don't know about equivalent FETs, but Banzai has the 2n5461 p-channel FET here:
http://www.banzaimusic.com/2N5461.html
I hope it helps
cheers
PaoloV(Jaba)
LektroiD
PostPosted: Thu Mar 07, 2013 10:02 am    Post subject: Re: 2n5461 Reply with quote  Mark this post and the followings unread
Jaba wrote:
Hi LektroiD,
I hope it helps
cheers
PaoloV(Jaba)
€0.24 for the transistor, €7.95 for shipping Confused
I have to say projects that use rare parts are always problematic. I wish I'd noticed this sooner... Is it essential that is must be that exact transistor?
LektroiD
PostPosted: Thu Mar 07, 2013 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
i took a look at my conversation with scott stites and thomas henry from the beginning of this project, and if i got it correct any P-Channle JFET should do. you could use a socket to be on the safe side.
thomas' goal was to have curcuits that don't use rare parts. and i know scott used a NTE part.
BTW if the transistor is only 0,24 it is not a rare part, i would guess. you get it from reichelt.de, and they are not known for stocking rare parts... maybe it is just that P-channel is not that common as N-channel in general.
someone over at muffs is going to try different p-channel jfet's, so we will know more soon.
LektroiD
PostPosted: Tue Mar 12, 2013 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know this is a ridiculous question, but on the silkscreen the presets are shown to be a particular orientation. Is this necessary? I ask as the 25K ones I have are 1-turn and the dial is facing one way. I know I can also use 50K, I don't have enough spare...
I'm pretty certain of the answer here, but just wanted confirmation, just in case there's some magic ogre lurking in the wrong orientation...
LektroiD
PostPosted: Tue Mar 12, 2013 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
no. it doesn't matter. i myself mounted them all headed into the same direction, just for the asthetics...
Heavy Metal Kid
PostPosted: Fri Jun 14, 2013 2:24 pm    Post subject: Re: PCB offer: Thomas Henry's Controller LFO
Subject description: CHECK PM's
fonik wrote:
Probably a newbie question, but which 1/8" jack sockets fit the front panel PCB?
Also, that riser you have on the LED, what part is that?
PostPosted: Mon Jun 17, 2013 12:27 am    Post subject: Re: PCB offer: Thomas Henry's Controller LFO
the sockets are available from thonk in europe, or from erthenvar in northern america.
i got these LED raisers from a local dealer. do you need a mouser part#? would have to search that myself.
PostPosted: Mon Jun 17, 2013 12:29 am    Post subject: Reply with quote  Mark this post and the followings unread
no. this the footprint that came with the CAD.
Heavy Metal Kid
PostPosted: Thu Jun 27, 2013 2:47 am    Post subject: Re: PCB offer: Thomas Henry's Controller LFO
The sockets got here fast. I'll go look for the LED raiser myself.
bod
PostPosted: Thu Jul 18, 2013 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi fonik, do you have any PCBs for this left? I'd love a circuit PCB and a eurorack PCB, maybe even 2 of each if there's enough! Smile
Or maybe someone has a set spare that they'd be willing to part with?
Fingers crossed....
Bod
PostPosted: Tue Jul 30, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Fingers crossed....
Bod
sorry for the late reply, have been on a two weeks vacation w/o internet access.
anyways, i have PCBs left.
muziekzen
PostPosted: Wed Sep 04, 2013 10:44 am    Post subject: D2 Reply with quote  Mark this post and the followings unread
Hello,
I don't know if I am blind, but I just can not find D2 on the PCB..
can anyone help me on this? Smile
thank you
g
muziekzen
PostPosted: Wed Sep 04, 2013 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I apologize for my previous post.
I just read on the previous page that D2 is not needed.
g
PostPosted: Wed Sep 04, 2013 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i found it to be redundant, however, IF you experience double triggers you could mount it piggypack in parallel to R44.
PostPosted: Wed Sep 04, 2013 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, except that I found in my own particular build, without D2, the trigger was firing on the falling edge of the square out as well as the rising edge.
I put it down to component / build variation. It shouldn't be difficult to do the build without D2, and then add it if needed. If you want better detail, PM me and I can send a picture of how I did the mod.
Edit: Matthias beat me to it Smile
Jonachi
PostPosted: Thu Sep 26, 2013 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Are these still available!? PCB and Panel that is. If so where can I buy them?
Jonachi
PostPosted: Sun Oct 06, 2013 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Please?
PostPosted: Tue Oct 08, 2013 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
currently no circuit PCBs left, however, i re-ordered a very few spares to have complete sets again (still have some front panels and PCBs).
as soon as they arrived i will check my lists and see what is available for purchase...
the thing is, i don't run an online store and i don"t have stock. i just produce based on interest gathered the forum's threads started for that purpose.
Jonachi
PostPosted: Tue Oct 08, 2013 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great fonik! Sign up as "very interessted". I'm on muffwiggler aswell (same nick).
alangave
PostPosted: Sun Oct 20, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, Would be "very inteerested" too.
Indeed, if we can help you cleaning your extra stock!
Jonachi
PostPosted: Sun Oct 20, 2013 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, please let us know if (or when) these will be available again. I was late to the party!
yan6
PostPosted: Sat Oct 26, 2013 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I too am late to the game and would love one of these
Heavy Metal Kid
PostPosted: Wed Nov 20, 2013 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Alright, finally got around to building this.
Some questions arise:
- What is the purpose of the ferrite bead, since it can be substituted with a cable?
- What is special about the SP3T switch, compared to a SPST or SPDT? They seem to be harder to find, for one. Smile
- I have a hard time tracking down a 1uF disc capacitor. Will a 1uF monolithic ceramic capacitor do?
PostPosted: Thu Nov 21, 2013 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
ferrites filter noise. however, i build with 10R resistors first to have some short protection in case something is wrong with my build. most of the time i jut leave them in.
different manufacturers refer to the these toggle switches differently.
what you need is a single pole ON-ON-ON. and you are right, they are not that easy to get, i buy them from small bear. they have good prices that justify the postage:
smallbear SKU 0221C1
the BOM asks for a 1uF electrolytic (C12, polarized). or did you mean another cap?
Heavy Metal Kid
PostPosted: Fri Nov 22, 2013 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Alright, ordered them from Small Bear.
I must have made that 1uF ceramic disc up in my mind, disregard the question. Smile
