Buchlaesque CV processor: CALIIBRATION???
Page 1 of 1 [3 Posts]
tokyomatik
Audio files: 6
PostPosted: Sun Jun 16, 2013 2:35 pm    Post subject: Buchlaesque CV processor: CALIIBRATION??? Reply with quote  Mark this post and the followings unread
HI GUYS
I just finished the cv processor using the layout from Matthias and I love it
now i would like to know wich kind of calibration is required with that 10k trimmer???
PostPosted: Mon Jun 17, 2013 12:34 am    Post subject: Re: Buchlaesque CV processor: CALIIBRATION??? Reply with quote  Mark this post and the followings unread
tokyomatik wrote:
HI GUYS
the 10k sets the 0V at 12'o'clock of the pot.
if you use knobs with screws, or if you can rotate the pot itself you won't need it. but if you mounted the pot 100% correctly (perfect angle), and if you used push on knobs, then you would need that trimmer to get the 0V at the 12'o'clock position...
tokyomatik
Audio files: 6
PostPosted: Mon Jun 17, 2013 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, so, since i have pots with screws the calibratiion is not needed...by the way i love this little module, i was missing so much a bit of glide in my basslines Laughing thanks again for make this layout available
