 Forum index » DIY Hardware and Software » emSynth
emSynth Actual Designs
Page 1 of 1 [4 Posts]
Inventor
Audio files: 267
PostPosted: Sat Jun 08, 2013 6:26 pm    Post subject: emSynth Actual Designs
Subject description: New Product Announcements Here
When I had built the first board (yesterday), it just begged for more. I wanted greater circuit density and dreamed of a processor daughtercard. Then I realized a way to connect two existing Generation 3 boards together in parallel. Thus the double emSynth board is born. I'll get a photo tomorrow if I remember.
Les
Inventor
Audio files: 267
PostPosted: Wed Jun 19, 2013 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are the two illustrations that I used in creating the latest demo, which is on youtube and mp3.
Les
 Filesize:  36.85 KB
 Viewed:  14661 Time(s)
 Filesize:  10.63 KB
 Viewed:  14662 Time(s)
Inventor
Audio files: 267
PostPosted: Fri Jun 21, 2013 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I have written a song component voice on an emSynth board and hooked it up to an R2R ladder at 5 bits of output. It sounds good but is not sinusoidal, has a sinsoidal envelope though. I think the bits are reversed, will check later.
Les
p.s. sounds good!
elektromeister
PostPosted: Tue Oct 17, 2023 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
You may adjust the resistors in order to get a perfect sine.
music is the key
