cappy2112
Joined: Dec 24, 2004 Posts: 2505 Location: San Jose, California
BobTheDog
Posted: Sun Jun 16, 2013 1:54 pm Post subject:
| Thanks for the link. |
clementshawes
Posted: Mon Jul 01, 2013 1:31 pm Post subject:
Grabbed this last night and got it working via the recommended Audio HiJack app. I didn't play yet though as I've not found the time to hook everything up and get lost in sound. _________________ Crumar Bit 01, Roland SH32, 12u/104hp modular (90% DIY).
Ableton Live Suite 9, Max 7 |
EdisonRex
Audio files: 172
Posted: Sun Jul 07, 2013 1:38 am Post subject:
I got this working (as much as I could get it to work without the <nuke> interface, that is). It is a bit CPU heavy, which is puzzling because when it was written I think CPUs had even less power, but probably that's just the inefficiencies of OSX at play. Pretty neat to use with the Eigenharp.
I've followed this particular area for many years as I own a Neuron keyboard. It's nice to see some movement again. _________________ Garret: It's so retro.
clementshawes
Posted: Sun Jul 07, 2013 6:56 am Post subject:
I've not had much time to use this virtual synth yet but the error message is superfluous from what I read on other forums; I'm nothing like experienced and only basing this comment on my ill knowledge and forum guff...
The controller just uses knobs and joysticks to send cc data, so far as I know. Surely it's just a case of marrying the correct CC values up and assigning them?
As to the inefficiencies of OSX - am I correct in thinking that this software was never written to work on the modern X and Cocoa frameworks of post 10.4 OS?
All that aside - dying to get hands on with this beast... _________________ Crumar Bit 01, Roland SH32, 12u/104hp modular (90% DIY).
EdisonRex
Audio files: 172
Posted: Mon Jul 08, 2013 7:55 am Post subject:
| clementshawes wrote: | I've not had much time to use this virtual synth yet but the error message is superfluous from what I read on other forums; I'm nothing like experienced and only basing this comment on my ill knowledge and forum guff...
No, my understanding is that the USB driver for the <nuke> is not continuous control midi data. Stefan Bernsee has discussed this somewhere.
| Quote: |
All that aside - dying to get hands on with this beast... |
No, the problem was that there was no build for Intel. You can still run the original VST if you're on a power pc. _________________ Garret: It's so retro.
clementshawes
Posted: Mon Jul 08, 2013 8:05 am Post subject:
Judging by the performance on my quad-core i5 Mac, I'd hate to attempt running it on any Gx PPC models lol!
read a thread on the KVR forum that someone was attempting to catch the messages the nuke sends and either emulate or otherwise replicate that data-flow by any means possible; good luck to them lol _________________ Crumar Bit 01, Roland SH32, 12u/104hp modular (90% DIY).
clementshawes
EdisonRex
Audio files: 172
Posted: Mon Jul 08, 2013 12:26 pm Post subject:
Indeed. I wish the developer would just convert the thing to allow CC messages to control the joysticks, but I can understand why not.
It used to run ok apparently on the older macs. I was a bit surprised at the CPU usage on my 2009 Macbook Pro. But then again, Intel doesn't do some things as efficiently as the PowerPC chips did. It's still worth checking out. _________________ Garret: It's so retro.
BigShort
Posted: Sun Jul 14, 2013 1:05 am Post subject:
i've a mac mini 2,6 Ghz Intel Core i7 and OSX 10.8.4.
After trying it with the recommend Plogue Bidule 0.9370 it works quite well like EdisonRex described.
But when i came to the point to record some nice sounds i tried it with Ableton Live 9.
After wrapping the Neuron Version 1.56 Update with FXPansion VST to AU Adapter v2.0 i got a very well sounding and working AU for Live 9. The "No Nuke" message was gone and i could change many parameters with my mouse. In the Instrument Device View i could drive mith my mouse through many of two Resys parameters simultaneous and i can control 32 Resys Parameters in the Device View with CC from my Nord Modular G2.
But till now i had no success using any of the CC Messages they are written in the manual page 181 to control the Neuron from my Nord Modular G2.
Maybe i'm too stupid and some help would be necessary  |
EdisonRex
Audio files: 172
Posted: Wed Jul 17, 2013 2:17 am Post subject:
That is the problem I have, although looking closer at it I am probably not mapping the CC messages into the VST correctly. It looks like the scape parameters are all mappable so I will try that too.
G2 should be able to do this - make sure it is not set to global I think. Maybe ask Wout (who probably doesn't see this thread). _________________ Garret: It's so retro.
BigShort
Posted: Mon Aug 05, 2013 12:49 am Post subject:
because of some long midi lags between my midisport 2x2 and Live 9 i tried successfull the combi Plogue Bidule 0.9730 (Master) & Live 9 in rewire mode. Till now this is the best solution sounding very well and without midi lag. In Plogue the presets of the neuron are CC able. On the Remote Page of the neuron are many params controllable with mod wheel and others + CC 03.
Now i've fun with the free plug. But if you have an iPad with Lemur you can control neuron similar like with the Nuke Stick.
For making own sound models i use Live 9 recording the output of Bidule and the ModelMaker of Neuron (only works for me on Windows 7) |
BigShort
Posted: Tue Aug 06, 2013 5:06 pm Post subject:
today i made a test in global mode - it works  |
clementshawes
Posted: Sat Jul 05, 2014 5:14 pm Post subject:
You've managed to emulate the Nuke controller with Lemur? _________________ Crumar Bit 01, Roland SH32, 12u/104hp modular (90% DIY).
BigShort
