today> Twyndyllyngs Chez Mosc
VCO for Ken Stones Wavetable-Modul
Page 1 of 1 [14 Posts]
Boerge
PostPosted: Tue Aug 13, 2013 3:35 am    Post subject: VCO for Ken Stones Wavetable-Modul Reply with quote  Mark this post and the followings unread
Is there any discrete VCO suitable for Ken Stones Wavetable-Module?
(This one: http://www.cgs.synth.net/modules/wavetable.html )
I know that it is based on the Digisound-VCDO, which uses a CEM-VCO. I would like to make a discrete VCO (I got no CEMs Sad ), but which circuit would be fast enough? The frequency needs to be 64 times higher than the played key...
regards
Boerge
...ich will doch nur löten...
fluxmonkey
PostPosted: Wed Aug 14, 2013 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
https://sites.google.com/site/hearnmorley/products/hmvco1b
www.fluxmonkey.com
forbin
PostPosted: Thu Aug 15, 2013 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
ideally you need a vco that is running about x256 or so of the frequency you want -- maybe the Thomas Henry x4046 with a smaller capacitor/Ian Fritz's Double Decka Core/Tim Sinchcombes SCF VCF's oscillator...
Boerge
PostPosted: Thu Aug 15, 2013 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why 256? Each waveform has 64 bitpatterns in the ROM, so 64x higher frequency should be enough. But as you mentioned the 4046: how is the settling time (? find no better word Wink ) of a 4046-PLL? Could one use a normal VCO and multiply the frequency by 64 with the PLL? Or would be a audible delay (or something like portamento) there?
forbin
PostPosted: Fri Aug 16, 2013 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
your right about the 64 step waveforms -- i was pretty sure that they were 8 bit wide but that as a newer wavetable vco -- you are still going to need a pretty high frequency vco though... if you want to go to 18kHz or so then you are going to need around a 1MHz -- you could try and phase lock but as you predicted you would get some slight glitchiness on transitions -- Thomas Henry's x4046 is actually a nice VCO and tracks pretty well -- see http://electro-music.com/forum/topic-42721-75.html at those frequencies you might want to loose all the bits hanging off the capacitor though as i suspect the input capacitance of the TL084 would start to be a consideration (the bits that generate the triangle/sawtooth waveform -- which you don't really need in this application anyway)
wmonk
Audio files: 15
PostPosted: Fri Aug 16, 2013 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about the core of the Ian Fritz DoubleDeka? That one has a higher frequency too. Smile
Weblog!
forbin
PostPosted: Fri Aug 16, 2013 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh that's true. It uses that slightly freaky Voltage to Frequency chip from NatSemi (well TI now, if they haven't discontinued it...)
Mongo1
PostPosted: Tue Aug 20, 2013 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I may be wrong, but you might also be able to use the Fritz Teezer core. That thing has quite a good range on it!
Earlier you asked if you could use a regular VCO and the use the 4046 to phase lock to it. I think the short answer is 'no' - it would require a very wide range, and really complicated loop filter.
Gary
KnobHell
PostPosted: Mon Aug 26, 2013 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where do you find the wave tables?
Boerge
PostPosted: Mon Aug 26, 2013 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, that was a bit tricky Wink I searched for the original Digisound ROM image, and found it long ago somewhere in the web. And I remember a website too, where you could make your own patterns, directly on the site or via downloading a little tool for that. I must dig in my archive Wink
forbin
PostPosted: Tue Aug 27, 2013 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I assume that you know about these?
http://www.adventurekid.se/akrt/waveforms/adventure-kid-waveforms/
KnobHell
PostPosted: Tue Aug 27, 2013 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, I'll check them out.
Thanks
Boerge
PostPosted: Fri Nov 08, 2013 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Found it, finally Wink
http://www.synthfool.com/docs/Digisound/
Greetings
Boerge
KnobHell
PostPosted: Sat Nov 09, 2013 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, thank you!
len
Greetings
Boerge
