[interest check] Nonlinearcircuits Neuron / Diff Rect
Page 1 of 1 [4 Posts]
kurodama
PostPosted: Thu Sep 05, 2013 12:16 am    Post subject:  [interest check] Nonlinearcircuits Neuron / Diff Rect Reply with quote  Mark this post and the followings unread
I think first of all this post need a little introduction of my person. My real name is Hannes and I am an illustrator and graphic designer by trade. In the last year I have started to work more and more on graphic design for eurorack panels. My main clients right now are Mutable Instruments and Hexinverter.net.
You can see some of my works here: http://www.papernoise.net/category/portfolio/instruments/
I have since also started to work on some panels on my own, focusing on projects that didn't have a panel already.
The first one is a eurorack panel for the Neuron/Diff rect by Nonlinearcircuits (see below for more info)
some more info:
• the panel is for a dual Neuron/Diff rect, meaning that you'll need to two PCBs from Nonlinearcircuits to build one of those
• This is a 12HP eurorack panel
• To make the panel more compact a tredoff has been made: you will not be able to solder the pots straight onto the PCB, but will have wire the pots to the PCB and will have to fix the pcbs to the panel with something.
So to sum up the current state:
1) the Neuron / Diff rect module is a really cool project and it's a pity it does not have a panel yet
2) If you don't know it yet, here's a link to AndrewF's page
Or even better a video:
http://www.youtube.com/watch?v=rkOX40dvHEw
3) the price for a single dual panel currently is 17 EURO. Production will start when I have interest for about 40 panels (there's about 20 left for the first run, which will consist of 50 panels, though of course I can always produce more if interest is high
4) since I started to work on this also Clarke68 came up with a panel of his own, which is a bit different in design and concept.
Here's the lastest version of the panel
www.papernoise.net | kvsu.net
kurodama
PostPosted: Thu Sep 05, 2013 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
update: I've finalized the panel after some feedback from Andrew from Nonlinearcircuits. It's now final and ready for production.
kurodama
PostPosted: Thu Sep 05, 2013 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
btw. this is the thread for the panel on Muff Wiggler:
http://www.muffwiggler.com/forum/topic-90763.html&highlight=
kurodama
PostPosted: Tue Sep 17, 2013 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just FYI these are currently being manufactured (got most of the seats full at Muff Wiggler) but there's probably some left to have, so if anybody is interested drop me a line
