 Forum index » Instruments and Equipment » Waldorf
Problem with Waldorf PPG Wave 3.V
Nurmi
PostPosted: Fri Oct 04, 2013 12:33 pm    Post subject: Problem with Waldorf PPG Wave 3.V Reply with quote  Mark this post and the followings unread
Hi everybody,
I have the following problem: I own the Waldorf PPG Wave 3.V, this works just fine in Cubase 5
Only when I run this in Cubase 6, the virtual keyboard at the Waldorf PPG Wave 3.V plugin can not be operated.
Why is that? I am running Cubase 6 on XP? But all other plugins are running correctly.
Can you help?
Thank you very much
greetings
Ralf
