today> Twyndyllyngs Chez Mosc
Sawtooth VCO - help!!!
Page 1 of 3 [52 Posts]
Goto page: 1, 2, 3 Next
synchroma
PostPosted: Sun Sep 29, 2013 6:35 am    Post subject:  Sawtooth VCO - help!!!
Subject description: I built a Bernie Hutchins sawtooth VCO and can't get it to work properly
Can anyone help me out here? I'm losing the will to live.
My 3rd attempt at building an integrator + reset sawtooth VCO.
I'm following the schematics for the ENS 76 VCO option 1:
http://www.synthsource.com/ens76/vco2.htm
But for the exponential converter I'm following Ian Fritz' Sawtooth VCO schematics:
http://home.comcast.net/~ijfritz/sy_cir2.htm
It doesn't make any sense: all I get is a vaguely trapiezoidal wave at ~200KHz. Panel controls don't make any difference.
Sorry about the DesignSpark schematics - I've tried to make them as readable as possible. Panel controls are on a separate board and are not shown, but they closely follow the Ian Fritz schematic with the addition of an extra exponential FM control+socket.
And this is the exponential converter
 Filesize:  78.08 KB
 Viewed:  337 Time(s)
This is the ENS-76 VCO option 1 board
 Filesize:  96.89 KB
 Viewed:  308 Time(s)
This is the output of the oscillator
 Filesize:  177.96 KB
 Viewed:  321 Time(s)
synchroma
PostPosted: Sun Sep 29, 2013 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, by the way, the 1.5K resistor in the sawtooth schematic is actually a 15K resistor. I already spotted and corrected this error.
PostPosted: Sun Sep 29, 2013 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very high frequency oscillation sometimes means your op amps need compensating capacitors, usually in the 10pF to 100pF range (I'd start smaller and work up).
Dunno if that's much help, but probably worth a shot Smile
synchroma
PostPosted: Sun Sep 29, 2013 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
There was one on the original Electronotes schematic. Bernie Hutchins hinted that it might no be necessary if you used an LF351 which is what I actually used, but I think you might be right. The first schematic has a 39pF cap as compensation.
I'll try it, and let you know how I get on.
Thanks,
Ed
piedwagtail
PostPosted: Sun Sep 29, 2013 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Best to help yourself by reducing the risk of it not working.
Junk the expo circuit and mock up a simple linear one instead to first get the integrator working, then re-introduce the expo. Don't try and solve too many variables.Keep looking.Use a continuity tester to check joints.
The elephant in the room is the the jfet
http://www.geofex.com/article_folders/fetmatch/fetmatch.htm
how many have you tried?
R
synchroma
PostPosted: Mon Sep 30, 2013 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah. Ouch!
Too many variables, but I'm determined to get a reliable design together. I'll try a linear current source with it. I've been going down the road of gradually splitting everything into it's component parts, which is why I'm only building the core of the VCO here.
JFETS - they do seem like a poisoned chalice in terms of reliability and specification. I am thinking that maybe a fast analogue switch like 1/4 of a CD4066 would be better.
synchroma
PostPosted: Mon Sep 30, 2013 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes, only tried the 2N4391 so far. I have a 2N4859and a 2N4856 somewhere, so I think I'm going to build another with a transistor socket to test them.
jackdamery
PostPosted: Mon Sep 30, 2013 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you building this particular VCO for any reason? If not, I can suggest an easier one.
If yes,
How many volts are you supplying it?
First thing, remove the expo converter circuit so you can just troubleshoot the oscillator. Connect a pot biased between +V and -V to the input. Tweak the pot until you get the slowest possible oscillation.
Try increasing the value of the capacitor (C2) between the comparators input and output to ~100pf. If this makes no difference then...
Try using a larger cap in the integrator. increase 2.2n to 10n. If this makes no difference...
Try a Tl071 instead of a LM311 for the comparator. You will definitely need C2 to be 100pf for this. If its still too fast increase C2 to a higher value.
Replace the voltage divider on pin 3 of the comparator with a pot so you can adjust the level at which the oscillator resets.
Re: the JFET. You can also try a BF245.
Jerry_100
PostPosted: Mon Sep 30, 2013 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Is U4 meant to be a dual power supply since the original circuit IC2 runs single power supply ?
frijitz
Audio files: 54
PostPosted: Mon Sep 30, 2013 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
It probably won't work with a TL071 for the integrator. It's a tight design, and you cannot just make arbitrary component substitutions.
Ian
jackdamery
PostPosted: Tue Oct 01, 2013 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Do you mean the comparator? I subbed the TL080 in the Jupiter 8 - a similar circuit for a TL071 and it performed just fine.
synchroma can you point your oscilloscope at pin 7 of the LM311 so we can see what the comparator is doing. I suspect the pulse width is too long and we are seeing the integrator charge to full (the ramp) then wait to be reset (the flat line) then discharge slowly (the falling ramp).
frijitz
Audio files: 54
PostPosted: Tue Oct 01, 2013 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I meant what I said. And I don't see how your Jupiter 8 comparison is relevant.
Ian
synchroma
PostPosted: Fri Oct 04, 2013 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK. I'm beginning to realise how critical the choice of op amp is for many of the designs I find out there! Apologies for using the "TL071" symbol in my schematic - it was a means to an end to get a working symbol/PCB component. I realised I had a fairly bogus Eagle op-amp library I imported into my CAD package with the wrong pinouts, and had to go with the crappy downloadable part spec from the software makers :-/
So, the TL071 is actually an LF351 in the circuit. Forgot to mention it, sorry! I was going with what Bernie Hutchins wrote that "You can also use an LF351 for the CA3140. You can also use an LF351 for the CA3130, but it would be run on the bipolar supply, and without the 39p compensating capacitor." (source: http://www.synthsource.com/ens76/vco4.htm )
It seems that this is incorrect. It didn't work.
So...I've bought a load of components: CA3130 and CA3140, OPA2132 (can't seem to get the OPA132 in the UK) LM311 and LM319 comparators, LM329DZ precision regulator and a bunch of other tightly spec-ed components (2N4391, 2N4859, 60K4 resistor etc). And, I've made a board with three different saw cores on it which (if my kids let me) I'll solder and test over the weekend.
Hutchins / Mikulic (ENS 76)
Rene Schmitz
Ian Fritz (with the other half of the LM319 used for PWM)
I still have the expos I made from Ian Fritz's design so I'll plug them in once I know the saw cores work (I'll knock up a linear current source to test them first).
Only top copper is shown. If they all work as intended, and if there is some interest, I'll make the design available here.
 Filesize:  712.11 KB
 Viewed:  274 Time(s)
synchroma
PostPosted: Fri Oct 04, 2013 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
PS jackdamery, thanks for your tips. The most useful here. I need to understand the relationships between reset time, slew rate and capacitor value. I'll experiment with what I've got.
Thanks,
Ed
synchroma
PostPosted: Sun Oct 06, 2013 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I notice that threads go cold on this forum after the first post from everyone. So, I'll start a new thread with the results I have from my build, which is less than encouraging as far as me working this out is concerned!
If only Thomas Henry had an integrator+reset design. His designs actually work.
I have now etched an built 5 sawtooth VCO cores without a single working oscillator. Mighty miffed.
PostPosted: Sun Oct 06, 2013 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electronotes.netfirms.com/EN194.pdf
If one of those doesn't work, I don't know what to tell you Very Happy
synchroma
PostPosted: Sun Oct 06, 2013 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey elmegil, Thanks for staying on board.
the ENS 76 is to the left here. It's the only one of these that does anythong - but all it does is charge, no reset.
I'm going to experiment with different capacitor values for the reset cap to see if I can get it into life.
 Filesize:  226.77 KB
 Viewed:  233 Time(s)
PostPosted: Sun Oct 06, 2013 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's the other side of the board look like?
synchroma
PostPosted: Mon Oct 07, 2013 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the board, both the artwork and a superimposed component view. It's not very well labelled I'm afraid, but I've taken as much care as possible to follow the schematics I found online. You can view the full 600dpi from the zip file.
A few changes - the ENS76 Option 1 VCO has two voltage followers providing 2 outputs (LF353 to the right of the board) and I've put together a PWM section from the other half of the LM319 in Ian Fritz's schematic.
 Filesize:  433.47 KB
 Viewed:  231 Time(s)
 Filesize:  291.16 KB
 Viewed:  278 Time(s)
SawCores.zip
 Filename:  SawCores.zip
 Filesize:  1.78 MB
 Downloaded:  211 Time(s)
synchroma
PostPosted: Mon Oct 07, 2013 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes I forgot to mention - the first version I made that started this thread off - the JFET connections were wrong. I've been double-careful to get them right this time.
PostPosted: Mon Oct 07, 2013 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That helps, but I was actually more interested in a photo of the back of the board Smile
synchroma
PostPosted: Mon Oct 07, 2013 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, OK this.
The black wire is an extra earth connection back to the PSU (as per the Rene Schmitz design)
 Filesize:  727.96 KB
 Viewed:  273 Time(s)
synchroma
PostPosted: Mon Oct 07, 2013 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way all, the waveform at the top of this post was gone after I tested it again. It went back to what I've got each time - the capacitor charges and keeps on charging - no reset.
I think I'm going to build some test circuits to see if my chips are fried.
PostPosted: Mon Oct 07, 2013 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your 3130 doesn't have the compensating capacitor between pins 1 & 8 that is in the original.
In the original circuit, the 3130 is powered single supply, so pin 4 is ground, not Vss.
Here's the schematic I'm reading that from: http://www.synthsource.com/ens76/vco2.htm (2 refers to page number, not option number).
Does anyone else know if there's a decent way to test an expo converter by itself? That's the other place I'd be looking, but I'm not sure whether running a resistor to ground would let you check the output or would just load it down.
synchroma
PostPosted: Tue Oct 08, 2013 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It does indeed have the compensating cap. And it is run at +15V and ground, as in the original. See the image below...After the first failed attempt I remade the board with exact matches for all components - I couldn't find a 39pF cap though - I used 33pF. Perhaps I should parallel a 10pF cap with it to make 43pF? I'll try this later when I get back to the lab.
I'd also like to find out how to test an expo on its own. I would have thought that running a resistor to ground would do it though, since expos are usually designed to produce changes in current. So loading an expo designed to peak at 1mA with a 1K resistor should produce a voltage that goes up to 1V, since V = IR
 Filesize:  164.59 KB
 Viewed:  252 Time(s)
