OTAs & SPICE
Page 1 of 1 [5 Posts]
PostPosted: Mon Oct 14, 2013 9:51 pm    Post subject: OTAs & SPICE Reply with quote  Mark this post and the followings unread
I have a Mac, that already puts me at a disadvantage Smile
I do have an LTSpiceIV implementation that wraps the windows code with the WINE simulator and it appears to work.
I have found CA3080 and LM13700 models and put them in the appropriate places (I think).
But I have not found a readily available OTA symbol, and I'm not sure I'm up for diving straight into designing a new symbol (yes, I can start from an Op Amp, but...).
Anyone have a generic OTA symbol or specific ones for either of these models?
gdavis
PostPosted: Mon Oct 14, 2013 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I changed the extension to .txt so I could attach it. Just change it back to .asy.
lm13700.txt
 Filename:  lm13700.txt
 Filesize:  2.21 KB
 Downloaded:  370 Time(s)
PostPosted: Mon Oct 14, 2013 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Boerge
PostPosted: Mon Oct 14, 2013 10:39 pm    Post subject: Re: OTAs & SPICE Reply with quote  Mark this post and the followings unread
Hi, there is a Yahoo-Group about Spice, in their Files-Section you can find three ZIP-Files lib_part1 to lib_part3, where are OTAs inside. Maybe it's what you are looking for.
regards
Boerge
...ich will doch nur löten...
PostPosted: Tue Oct 15, 2013 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the pointer...
Edit: frustrated with Yahoo Groups, cannot seem to find a search, the files are not obvious Sad
Edit2: aha, found the "LTSpiceFiles" group, "LTSpice" group does not have them.
Thank you again, I'm good now Very Happy
