rjd2
Posted: Fri Dec 06, 2013 1:49 pm Post subject:
Help on a capacitor substitution Subject description: can a .047uf bypass go up or down? |
hi all, hopefully a quick question.
restoring a Yamaha CS-40M. on the attached board, there are a bunch of .047uf poly caps that look like they function as bypass caps to the -15V rail, and are toast. i need to sub them out.
i've got a gang of caps laying around, but not enough .047uf(and ceramic, at that) to do the whole board. my question: can i go up or down on the value for this application, you think? and can i use ceramic? thanks for the help.
| Description: |
| Filesize: |
3.86 MB |
| Viewed: |
215 Time(s) |
| Description: |
| Filesize: |
1.92 MB |
| Viewed: |
265 Time(s) |
Osal
Posted: Sun Dec 08, 2013 10:16 am Post subject:
Re: Help on a capacitor substitution Subject description: can a .047uf bypass go up or down? |
| rjd2 wrote: | hi all, hopefully a quick question.
i've got a gang of caps laying around, but not enough .047uf(and ceramic, at that) to do the whole board. my question: can i go up or down on the value for this application, you think? and can i use ceramic? thanks for the help. |
These capacitors hold the analog value from the demultiplexer ym617. You can read the explanation in pages 28-29 of the hardware manual:
here
It is interesting the lecture from page 1 to 29 though.
So, as I understand, the capacitors must be enough large to hold the voltage value during 5ms but enough small to charge a new value during only 80 μs for each 5ms without a noticeable delay.
I would go for new 0.047uF polyester capacitors. _________________ electronic-sea.net |
