NullPointerException error
Page 1 of 1 [3 Posts]
shmoyko
PostPosted: Thu Dec 19, 2013 8:02 am    Post subject: NullPointerException error
Subject description: Tryint to dynamically create a two-oscillator synth
Hello all,
I just finished the ChucK Coursera course and wanted to try building a simple 2-oscillator bass synth.
The synth is a class and the user can choose what each oscillator should be (e.g. SinOsc or TriOsc). In order to achieve this, I need to somehow create oscillators dynamically. But, that's when I run into problems.
Here's the code I have so far: http://pastebin.com/BCuYbVWL
I understand why I'm getting the NullPointerException error, but just can't figure out how to build the oscillators "dynamically".
Does anyone have examples of something like this?
Many thanks.
fretless
PostPosted: Thu Dec 19, 2013 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
public class EitherOrBass extends Chubgraph
    SinOsc s0, s1;
    TriOsc t0, t1;
    int which;
    fun void init (int Qsin)
        Qsin => this.which;
        if(Qsin){s0 => outlet; s1 => outlet; 0.1 => s0.gain => s1.gain;}
        else {t0 => outlet; t1 => outlet; 0.1 => t0.gain => t1.gain;}
    fun void Play (float f0, float f1)
        if(this.which){f0 => s0.freq;f1 => s1.freq;}
        else {f0 => t0.freq;f1 => t1.freq;}
    EitherOrBass FL;
    1 => FL.init;
    FL => NRev verb => dac;
    0.234 => verb.mix;
    float note;
    while(true)
        Math.random2f(45.0, 200.0) % 30. * 7.  => note;
        FL.Play(note, note*2.);
        0.15::second => now;
shmoyko
PostPosted: Thu Dec 26, 2013 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. Neat solution, although, if I'm not mistaken, you not dynamically generating oscillators, but connecting them to the Chubgraph outlet as needed.
I guess there's no other way.
