Trimming down Alpha pots
Page 1 of 1 [9 Posts]
Zodiak
PostPosted: Sun Jan 12, 2014 5:31 pm    Post subject: Trimming down Alpha pots Reply with quote  Mark this post and the followings unread
I am more than happy with the Alpha pots recommended by the good folks here, they are superb and am happy that I changed.
There is however one slight niggle in that I can't find a knob that I am happy with that covers up the mounding nut so was wondering about cutting the shaft down by 5mm so that my existing ones would fit. Shocked
Has anybody tried this and how did it turn out? Confused
Thanks
Stephen
www.Rainsbury.Net
The Bad Producer
PostPosted: Mon Jan 13, 2014 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I do this using some bolt cutter type pliers - quick and easy! I have tried sawing with a hacksaw years ago, but you get lots of metal dust...
The bolt cutters I have are little hand held ones with a 'levering-mechanism' that makes them cut harder (applies more pressure) than just you're normal cutters... oh here they are;
http://www.techool.com/productinfo.asp?pid=176&cid=7
Forge Steel Extra Leverage Pliers
Charlie
Zodiak
PostPosted: Mon Jan 13, 2014 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I have only chopped down plastic pot shafts with cutters. I can see what you mean about the dust and I was thinking of using a cutting disk on a dremel so maybe I need to re-think that.
Stephen
www.Rainsbury.Net
analog_backlash
Audio files: 21
PostPosted: Mon Jan 13, 2014 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I do! I tend to hold the pot upside-down whilst doing it, but I suppose some metal dust could still get in. The cutters seem like a better idea, but I don't have any like that (yet). The only downside is that you don't get a nice stream of sparks that way Laughing .
Gary
scriptstyle
PostPosted: Tue Jan 14, 2014 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember buying extra long alpha pots long ago, i just put the shaft horizontally into the bench vise and hackjob... all dust goes down hold the pot with a plastic bag
Zodiak
PostPosted: Tue Jan 14, 2014 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I have already had to change the pots once as I was having problems with the Omeg plastic ones, and having just rewired all 29 I don't want to remove them now, so its going to be careful masking with selotape and clingfilm , and then out with the dremel and disk. Confused
My main concern was that I was going to somehow screw the pooch by cutting the shafts to size and that no knob ever made would stay put afterwards.
Stephen
www.Rainsbury.Net
diablojoy
PostPosted: Tue Jan 14, 2014 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
measure the depth of the hole in the knob and cut the shaft down to that length taken from the end of the threaded bushing.
or another way is to mount the pot on the panel push the knob on then measure from the bottom of the knob to the panel surface and cut that much off minus a millimeter or so to keep it off the panel surface.
by the way i use a hacksaw, a vice and a fine file.
ask where the hell am I
as good an answer as any
frijitz
Audio files: 54
PostPosted: Wed Jan 15, 2014 12:16 pm    Post subject: Re: Trimming down Alpha pots Reply with quote  Mark this post and the followings unread
Zodiak wrote:
... was wondering about cutting the shaft down by 5mm so that my existing ones would fit. Shocked
Thanks
I just chuck the shaft up in the lathe and use a standard cutoff tool. The swarf is too big to get into the housing.
Ian
Broadwave
Audio files: 6
PostPosted: Fri Jan 17, 2014 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
One word… Dremel.
Can't live without mine Smile
TIP: Before you cut the shaft, mount the pot to a metal panel so it acts as a heatsink. I find that the lube inside the pot melts if it gets to hot when you're cutting (even with a hacksaw). It can end up with a "sloppy" feel otherwise.
