pt2399 and Lunetta
Page 1 of 1 [11 Posts]
DUBmatze
PostPosted: Tue Jan 21, 2014 10:43 am    Post subject: pt2399 and Lunetta Reply with quote  Mark this post and the followings unread
this chip is driving me crazy.
I already add pt2399 delays to a siren... i used a Rebote without any oamps. (like: http://guitarwork.ru/electronic/Other/Rebote_Delay/ )
but iam trying the last 3 evenings trying to get a simpler pt2399 work with my lunetta.
I tried the circuits from Phobos (moon base explorer and Pitch shift thingie). No success.
I read mutch about faked pt2399, and not starting oscillating circuits. I triple checked everything. (chips work in a rebote delay)
(why iam posting this in Lunetta forum?) I added two 4040 to the clock out (my scope is over 30 years old, up to 10mhz only). and i get a nice squarewave. (will use this as osc in the lunetta, and some extra blinking). so the osc will start.
the circuits dont work for me with or without a 4040 aded. so wats is the trick?
at the moment i have exact this on my Breadboard (2nd simplifieyd circuit, using 47n as c4 + c9, tried difrent values for c13 (1, 4.7, 10, 47u)) -> http://circuit-diagram.hqew.net/Digital-Delay-Unit-For-Surround-Sound$2c-Reverb-$26-Echo_13932.html ).
I run it from my Lunetta power suply a 7805, some caps. and i build a dedicatet (running from 12v adapter..). When i connect a 4093 osc to the input the sound disapear when i power the 2399... (tested diffrent input levels 50k pot)
what means " It is essential that the 5V supply has a low impedance," ?
the output i connect to a simple passiv mixer.
DUBmatze
PostPosted: Wed Jan 22, 2014 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
okäääääyy - now iam confused.
found 8x pt2399 - 4 working in this circuit and 4 are not working. (all work in my Rebotedelay). And some sounds a bit difredifferent.
missed here a groundconnection.
DUBmatze
PostPosted: Wed Jan 22, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
i uploadet a small test:
PostPosted: Wed Jan 22, 2014 6:13 am    Post subject: PT2399 tempo indicator Reply with quote  Mark this post and the followings unread
I don't know what´s causing the problems with the PT2399 (especially since some work and others don't). But I have a circuit you might find useful.
It's a tempo indicator using the CLK out pin and 2x 4040 (as you did) but with the diodes it's set to a specific number so it corresponds with the
delay rate. I think I got it from this thread. note that you have to use the 74HC4040, the CD4040 isn't fast enough.
tempo indicator for PT2399 delay chip.
 Filesize:  37.2 KB
 Viewed:  930 Time(s)
DUBmatze
PostPosted: Wed Jan 22, 2014 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
hey - thanks Phobos,
in my case the 4040 shud work. the datasheet of the 2399 say 10,5k resistor == 4,5 Mhz. the 4040 can handle 7Mhz (at 5V) so the 4040 shud work for evrybody who uses delays longer than 97ms (5,8k resistor) i think. (was try to figure out why its working the last 15min ... Wink )
in your circuit i dont get realy what the diodes doing there. (they keep the output high, but why?)
i using Q12 and Q7 == 19 stages (Q5 is only for some optical fx Wink )
your schematic uses Q10 and Q10 == 20 Stages - or do the diods somthing with the dividing? (i think my 19 Stages exact on the repeat of the echo, i testet with a short "ding sound" and watch the LED)
i googled pt2399 and 4040 after thinking about the divider and found this:
http://www.aronnelson.com/gallery/main.php/v/cathexis/Veroboard+Layouts/Magnus+Modulus/PT2399+Tempo+Indicator.jpg.html?g2_imageViewsIndex=1
thats the same like you posted (but i dont understand it)
(originally my hope was find a way to feed the clock in the chip)
btw - what program is this u use for the schematics phobos? (like the look and iam not realy happy with tinycad)
PostPosted: Thu Jan 23, 2014 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah I think you're correct, as long as you don't make the delay times to short it should work with a regular 4040. I know when I made the indicator
years ago it didn't work very well, untill I replaced the 4040 with 74HC4040's.
The diodes + pullup resistor function as a AND gate and are there to reset the counter once it has reached a specific number. As long as one of those
outputs is low the reset pin will be held low, only when all of those outputs are high the reset pin will be made high.
For the first counter it's 2^4 + 2^6 + 2^7 + 2^8 + 2^9 + 2^10 = 2000.
For the second counter it's 2^3 + 2^4 + 2^6 + 2^8 +2^10 = 1368
which makes the total count 2000 x 1368 = 2736000.
now if you look at the datasheet there is a table with the delay time and VCO frequency. I't not really linear so with a fixed divider it won't be exact
but it comes close. For a delay of 342mS the CLK out is 2MHz. 342mS -> 2.92Hz so the LED should flash at this rate. 2000000 / 2736000 = 0.73Hz
which seems too slow but 0.73Hz is exactly 2.92Hz / 4, so either it flashes at 1/4 of the actual delay rate or my calculations are off Cool
It would make sense to divide it by 4 since it would flash rather fast if you didn't.
The software I use to draw schematics is ExpressSCH
DUBmatze
PostPosted: Thu Jan 23, 2014 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks phobos for the explanation.
(cost me about one hour to get it and test a bit the ExpressSCH, but cant find a just empty dip16 chip. looks like i have to make some custom parts - phew... )
Wink
PostPosted: Thu Jan 23, 2014 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, you'll probably have to make custom parts quite often. Even the ones in the library aren't always useful. But you can select the component, then
go to "Component" > "Ungroup component", change it and then choose "Group to make component" which can save some time compared to drawing
it from scratch. And you can save it as custom component for future use. Also if you connect lines to eachother (cross or T) it doesn't always connect
them and then it doesn't show a dot on the connection when you export the schematic.
PostPosted: Thu Jan 23, 2014 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try increasing the resistor on pin 6. The oscillator sometimes doesn't work if the resistance is too low. You can then lower it after the circuit is powered on and oscillating.
DUBmatze
PostPosted: Fri Jan 24, 2014 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
mhm the osscilator is starting (i checked that with scope and the two 4040) i use a 12k resistor and a 50k pot. (other ppl use 2,2k and get starting problems with the osc.)
i dont investigate this any more ... it must be the PT2399... not me and not the circuit. (i change one from the not working to my rebote delay and still got 4 working here.... thats enouth echo for the next days Wink )
maybe i shud work on a springdelay but cant find a usefull spring...
DUBmatze
PostPosted: Wed Feb 19, 2014 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just paintet a few circuits from my black book (playing with expressSCH). This is what i made with my PT2399 notes... :
