CMOS "ribbon" "synth"
Page 1 of 2 [26 Posts]
DUBmatze
PostPosted: Sat Mar 15, 2014 2:32 pm    Post subject: CMOS "ribbon" "synth" Reply with quote  Mark this post and the followings unread
nothing special but my kids and me have a lot of fun with it Wink
--> http://matze.reggaestriert.de/lofi-ribbon-control/
analog_backlash
Audio files: 21
PostPosted: Mon Mar 17, 2014 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it DUBmatze! I've been thinking about doing a ribbon controller for my dormant Lunetta (I haven't worked on it for ages, because I've been in a really shitty mood lately). I was thinking of using a black electrically conductive bag and a length of ex guitar string as the basis for it. Perhaps I'll have go tomorrow and if I get anything useful out of it, I'll post the results. I've got to get back into building stuff again - it's the only thing that keeps me sane(ish) at the moment cyclops
Good work,
Gary
analog_backlash
Audio files: 21
PostPosted: Tue Mar 18, 2014 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi DUBmatze.
I threw together a simple ribbon controller today as you will see in the attached picture. I remembered that I had some aluminium tape, so I've used that as the "wiper" and the rest of the pot was made from an old conductive bag that components had been sent in. The picture shows one assembled ribbon controller and one yet to be built, showing the materials. I used some matrix board offcuts to act as spacers. The sample is of the ribbon connected to a very simple 40106 oscillator (which I already had on a breadboard). I added a bit of Audacity reverb to make it sound better Very Happy I was recording this "blind" (or should that be "deaf") as it was on a new laptop and I haven't worked out why it's not monitoring the input at the moment Rolling Eyes
Just thought you might like to hear it. I thought that it worked quite well considering how little effort I expended on it...
Gary
 Filesize:  414.58 KB
 Viewed:  575 Time(s)
Ribbon Controller Test.mp3
 Filename:  Ribbon Controller Test.mp3
 Filesize:  647.75 KB
 Downloaded:  1106 Time(s)
PostPosted: Tue Mar 18, 2014 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
great work,. both of you Very Happy
I've tested several different brands of VHS tape before to make a ribbon controller but never got anything that worked,
I might have some of those conductive bags though so I'll give that a try.
analog_backlash
Audio files: 21
PostPosted: Wed Mar 19, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PHOBoS Very Happy . I'm sure that you know this already, but the (usually) pink static dissipative bags don't work, which you can easily see by testing it with a multimeter. One of my suppliers often sends components in these black bags which are good electrical conductors. I've just measured the resistance end to end on mine and it's about 40K for a roughly 20cm length (but that will vary with source and presumably with width of the strip).
Gary
rumblin_cynth_rampo
PostPosted: Wed Mar 19, 2014 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats brilliant DubMatze! Sehr toll!
Recently I have been messing about with a Softpot ribbon on an op amp oscillator (not a VCO) and was really please with the results. But your is method is so much more appealing. For some reason I didnt think of trying the Softpot ribbon with CMOS stuff. Ill have to give that a go.
Ian "Lemmy" Kilmister on Hawkwind;
"Like Brahms but violent."
https://soundcloud.com/rumblin_cynth_rampo
PostPosted: Wed Mar 19, 2014 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
ah thanks, was about to ask that. I did test one black bag but couldn't measure anything so I guess it's not conductive. I do have some shiney
silvery ones, maybe those work. So I'll just test everything I can find and report any findings back here. Cool
edit: silvery ones didn't work but I found some more black ones which are labeled 'carbostat' and those do work (at least I measure a resistance) Laughing
I assume you just put some tension on it to keep it suspended above the aluminium tape (I got some of that too). With the size of the bags I got I
could make one as large as my whole hand, makes me wonder if it would be possible to make a sort of XY control surface.
Audio files: 304
PostPosted: Wed Mar 19, 2014 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian Fritz used to have some docs on how made a ribbon ... various types of tape to get the spacing right ... but can't find that website anymore .. there is some info here on the forums too .. googling Ian Fritz ribbon found some stuff, but not exactly what I had hoped to find back.
analog_backlash
Audio files: 21
PostPosted: Wed Mar 19, 2014 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
edit: silvery ones didn't work but I found some more black ones which are labeled 'carbostat' and those do work (at least I measure a resistance) Laughing I assume you just put some tension on it to keep it suspended above the aluminium tape (I got some of that too). With the size of the bags I got I could make one as large as my whole hand, makes me wonder if it would be possible to make a sort of XY control surface.
Yes, I had some silvery ones that don't conduct either. I did put some tension into it to keep it away from the aluminium tape (I need to straighten in out a bit as you can see from the photo). I held it in tension with bits of insulating tape before tightening the whole thing up. The XY control surface idea seem really intriguing - I'd like to see that if you can get it to work Cool
Gary
PostPosted: Wed Mar 19, 2014 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you mean this one. I was already looking for DIY ribbon controllers and got some inspiration on how to construct one.
edit: that's the stuff on the forum as you mentioned. yeah I think there was indeed a site or something
with a step by step guide. or maybe that's just some bad braincells.
Audio files: 304
PostPosted: Wed Mar 19, 2014 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe we share some bad brain cells then Shocked Laughing
PostPosted: Wed Mar 19, 2014 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I am he as you are he as you are me etc,..
I gathered some parts to give it a try.
- a piece of scrapwood that'll function as the base (I think it was part of a chair).
- two kinds of transparent plastic. one is just a thin transparent sheet that can be printed on, the other one is more sturdy probably about 0.3mm.
(I'll use the lather to cover the base since it's painted and therefor the surface isn't very smooth.)
- a couple of those conductive black bags
- double sided adhesive tape
- aluminium tape
maybe I should add a paperclip too,. just in case.
diy ribbon controller kit
 Filesize:  59.59 KB
 Viewed:  455 Time(s)
PostPosted: Wed Mar 19, 2014 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm just thinking,. you could use PCB material (with copper) instead of the aluminium tape. It's also pretty sturdy so you could mount the 'ribbon' on it
and then just glue/tape the whole thing on to whatever you want. oxidation might be a problem though.
Audio files: 304
PostPosted: Wed Mar 19, 2014 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
But then again aluminium oxidizes way faster than copper .. just looked it up, and Al2O3 is a bad conductor .. the layer however seems to get only 4 nm thick ... I had never noticed aluminium to not conduct, yet it always has an oxide layer.
Anyways .. I did make keys with PCB material, spacers made of PCB layout tape and then a layer of aluminium foil over it covered with a sheet of plastic ... it worked for several months at least ...
analog_backlash
Audio files: 21
PostPosted: Wed Mar 19, 2014 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes the conductivity of aluminium is a bit of a paradox which I should know the answer to (from my chemistry background) but I can't fully explain it Embarassed . As you say, aluminium is far more reactive than copper and very quickly forms a thin oxide coating (which should act as an insulator, as you say). It then stops reacting with the air because the coating effectively seals the metal off from further reaction. But, as you can easily tell with a multimeter, aluminium is a good electrical conductor (in fact, although it has a lower conductivity than copper, weight for weight you can produce lighter conductors from aluminium than copper which have similar electrical properties).
I'd have to do a bit of research on the insulating effect of Al2O3 on the metal, but practically, I've never had a problem (and I have had problems with old copper on PCBs). The only common problem which can occur is when it comes into contact with a less reactive metal (e.g. copper), but even then you'd need an electrolyte to start the corrosion off.
Audio files: 304
PostPosted: Wed Mar 19, 2014 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
[...] but I can't fully explain it
Neither could Google ... not only not at my level .. but did not find much on the subject really .. except that alu mains wiring caused some fires due to oxidation at contact areas ... so there does seem to be an effect even when I had never noticed it on alu foil.
But I doubt PHOBoS would start a fire with his experiments ;-)
PostPosted: Wed Mar 19, 2014 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I put it all together and it seems to work Very Happy
it's mostly made up of the thicker plastic held together with double sided adhesive tape. I'll post some construction pics and more info later.
I think I also have a large piece of the conductive foam somewhere so I might give that one a try aswell.
But I doubt PHOBoS would start a fire with his experiments Wink
actually I was thinking of something,.. if you wire it up as a voltage divider and press it down on both ends (2 fingers) you could fry it. Shocked
(has nothing to do with oxidation ofcourse).
But the measured resistance is 400K on my version with a length over 200mm. so that's almost 2K for 1mm, and the way it's constructed you
can't even get that close to the end points.
 Filesize:  94.3 KB
 Viewed:  350 Time(s)
analog_backlash
Audio files: 21
PostPosted: Wed Mar 19, 2014 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, aluminium can burn spectactularly under the right conditions, but unless PHOBoS has a few amps running through his ribbon controller, I think that it's quite safe Laughing .
analog_backlash
Audio files: 21
PostPosted: Thu Mar 20, 2014 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
actually I was thinking of something,.. if you wire it up as a voltage divider and press it down on both ends (2 fingers) you could fry it. Shocked (has nothing to do with oxidation ofcourse).
But the measured resistance is 400K on my version with a length over 200mm. so that's almost 2K for 1mm, and the way it's constructed you can't even get that close to the end points.
Thinking about it, to be on the safe side you could add a small fixed resistor on either side of the ribbon (in a voltage divider set up) just to make double sure that no frying could occur, but I expect that you've already thought of that...
Gary
PostPosted: Thu Mar 20, 2014 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I deed indeed think about that, but as mentioned the way it is constructed I have some extra resistance on the sides since I can't get completely to the end points
(the plastic insulation is slightly overlapping there), but it's still a good precaution.
I've seen several setups btw,. one that I find interesting is this one:
which can be found here (I took some ideas on how to construct it from that one Wink )
and I just noticed this at the bottom:
Ideas for future work
# Make a small 2D resistive touchpad from one inch wide tape (used on music studio multitrack reel-to-reel recorders, studio video tape, and probably also old computer storage)
# Use a custom PCB as base material instead of sticking copper tape on a plastic enclosure. It'd better be gold-finished than the rusty tin finish you get standard nowadays though.
Laughing
But I also like this Paia circuit Cool
PostPosted: Thu Mar 20, 2014 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Some info on how I constructed my ribbon. I actually made it the other way around so the resistive track is on the bottom and the ribbon has the
aluminium conductor. I think that this way there is less change of damaging the black plastic resistivestuff and if used as the ribbon the
flexing might change the total resistance slightly. Also if the ribbon get's damaged it's easier to make a new one with aluminum tape and you'll still
have the same total resistance.
I started with putting some double sided adhesive tape (I'll refer to it as dsat) on the thicker plastic, stuck a strip of the plastic bag on to it and
then cut a 15mm wide strip from that. I put some more dsat on a larger piece of the plastic and stuck the strip on it with two strips of plastic next
to it on both sides, which I then cut to size. So that gave me two layers of plastic with the resistive strip centered on top. I made contacts by folding
some pieces of the aluminium tape in half with the sticky stuff on the inside (this side does not conduct). The resistive strip is shorter then the
bottom piece of plastic so the dsat on that holds the contacts in place.
I cut two small pieces of plastic which I stuck on both ends which act as a spacer and insulator between the contacts and the ribbon on top. They
also provide enough pressure to get a connection between the contacts and the resistive track. I cut two more strip of plastic that fitted between
the two ends and stuck them on leaving a gap that's smaller then the ribbon. This will prevent the ribbon from touching the track when not pressed.
like the black spacer on this but made up of 4 pieces:
I then put some more dsat on both ends, stuck the contact and the ribbon on it and covered it with two small pieces of plastic (one on each side).
The ribbon was made by sticking the aluminium tape on the thin plastic sheet and cutting a 15mm strip from it. I used the white border on the
side so I got a nice white ribbon Very Happy The whole thing was then stuck to the wooden base (which I covered first with some self adhesive plastic that
has a woodprint on it) and I used thumbtacks to connect wires to the aluminium tape contacts.
 Filesize:  82.49 KB
 Viewed:  342 Time(s)
 Filesize:  88.47 KB
 Viewed:  406 Time(s)
 Filesize:  96.34 KB
 Viewed:  381 Time(s)
 Filesize:  76.27 KB
 Viewed:  294 Time(s)
PostPosted: Thu Mar 20, 2014 10:58 am    Post subject:   Reply with quote  Mark this post and the followings unread
So now I got a question for DUBmatze about the foam version that started the thread. Does the PCB (if that's what it is) between the two pieces of
foam have copper on one side to connect the +5V, or did you tape a wire along side of it (or through it) ?
DUBmatze
PostPosted: Thu Mar 20, 2014 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hehe,
looks a bit like ribbon is the thing ... ,) thanks for the credits.
in my version there are just 2 parts of foam ... the lower foam i just sew with a solid wire. the bright thing in the pic between the uper an lower part is just a pencil as spacer. if you put more fingers on it you get a lower resist. one foam never toch the other the conection are just the fingers. if you use more fingers or press more left or right you get other resistance. its not realy a ribbon .... its more like a tochpad.
I found a broken plastic breadboard with some glitter effect in it (not the electroc one just for cutting tomatos or bread on it). i thested this also and this is nice ..... kids playing it with a cucumber like a violin... (hint clean up after evry session this is going fast disgusting... baah)
PostPosted: Thu Mar 20, 2014 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you that made it perfectly clear Very Happy
cucumbers, hmm never though of that Shocked
PostPosted: Sat Mar 22, 2014 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I might as well join in the fun. A few months ago, I had built a makeshift ribbon controller for testing out my Pulse Witch 23 box. I had found some broadcast-format videotape in the trash that's about 15K / cm. So I mounted that floating above a flat strip of copper sheet.
In this video, I wired it as a voltage divider with a power source and a pot to control the range, so as to produce a CV I could use with my box. It's not that great with this box, i.e. in terms of precise control, but that's mainly because of how I handled the CV for this particular input (it goes straight into an LED/LDR pair... so there's the slow response of the LDR that's affecting it).
James.
