 Forum index » electro-music.com
New server is running
Page 2 of 2 [39 Posts]
Goto page: Previous 1, 2
Audio files: 310
PostPosted: Mon Mar 31, 2014 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
There are some more broken ones ...
http://radio.electro-music.com/
http://srv3.electro-music.com/
Unfortunately I could never find where these addresses are set ...
Audio files: 235
PostPosted: Tue Apr 01, 2014 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://event.electro-music.com/ takes me to the main electro page instead of the festival page. Confused
This link is still broken.
Fixed now. Thanks...
Acoustic Interloper
Audio files: 89
PostPosted: Tue Apr 01, 2014 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, Howard. I am promoting the event wow!
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
james004
PostPosted: Wed Apr 02, 2014 12:41 pm    Post subject: Registration issue Reply with quote  Mark this post and the followings unread
I unintentionally created a new topic when I intended to post this here. Sorry.
I am attempting to purchase the audio software in the electo-music.com store. But I am unable to register as the system is giving me the error below during the registration process.
"Your E-Mail Address does not appear to be valid - please make any necessary corrections."
However it is a valid email address and I tried another on a different domain with no joy. One address is a att.net the other yahoo.com.
Regards,
James
Audio files: 310
PostPosted: Wed Apr 02, 2014 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello James welcome
obviously the att email worked to get you signed up for the forum .. so must be valid enough Shocked
The shop is mosc's domain, so have to wait for him to see this. Meanwhile I'll remove that other message you posted.
BTW, as long as it is not replied you would be able to remove it yourself too - a next time.
Audio files: 281
PostPosted: Thu Apr 03, 2014 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if this is a bug, but I noticed that there are two ways you can link to a file for download, e.g. for my last AIS there are these links:
http://electro-music.com/forum/phpbb-files/adventures_in_sound_196_020414_723.mp3
or
http://electro-music.com/forum/download.php?id=37185
I usually use the first and I've just noticed that using this doesn't increment the number of downloads shown, but the second one does
Audio files: 310
PostPosted: Thu Apr 03, 2014 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It may be a bug Jez, but this has always been the case I think .. the phpbb-files link was supposed to be a secret I guess ...
Audio files: 281
PostPosted: Fri Apr 04, 2014 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I'll just have to use the boring link then Wink
Audio files: 235
PostPosted: Mon Apr 07, 2014 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
or
It's sort of an intentional bug. It allows people who post music on electro-music.com to use direct links from other web sites. As long as this isn't abused, we'll keep it this way.
Audio files: 235
PostPosted: Mon Apr 07, 2014 3:30 pm    Post subject: Re: Registration issue Reply with quote  Mark this post and the followings unread
Thanks, it is indeed a bug. I just fixed it. Please give it a try and if you still experience difficulty, let me know.
Thanks again.
PostPosted: Sun May 25, 2014 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Images don't show up on the radiopage when streaming, I think this was already (not)happening before the move.
Maybe it was turned off to prevent the page from loading slow when a large image is attached. Rolling Eyes
Audio files: 310
PostPosted: Sun May 25, 2014 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm ... the code looks like it should be working .. there are a couple of listeners right now, so not going to do any switching.
Will do it at some point when there is a switch active, prolly wednesday then when Jez or Rob is on.
Audio files: 310
PostPosted: Wed May 28, 2014 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fixed it :-)
Jez was active.
This was in the radiostats33.php script, it was trying to read relay data from srv3, but that data was not on srv3, it never was there .. it was on srv2, and now is on srv4, but there never was a need to qualify the request as such, as http://electro-music.com would go to srv2 before and goes to srv4 after the last server switch ... something like that ... so I just removed the srv3 bit from the request URL and (the http 1.1 required) host spec.
Edit: spelings and detail blahs
PostPosted: Wed May 28, 2014 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumleft
