 Forum index » DIY Hardware and Software » The Repair Shop
Transformer for Balanced to Unbalanced Adapter?
Page 1 of 1 [3 Posts]
johnyradio
PostPosted: Sun May 25, 2014 5:10 pm    Post subject: Transformer for Balanced to Unbalanced Adapter?
Subject description: which of these transformers would work?
Hi
I have a piece of gear with balanced outputs, and i need to send it to gear with UNbalanced inputs.
I want to build the adapter in the attached image, from:
http://www.rane.com/note110.html
(scroll down to "The Next Best Right Way To Do It")
Here's my question. Would any of the transformers below work for this purpose?
-Thx!
http://r.ebay.com/CWd0TA
http://r.ebay.com/yRsln2
http://r.ebay.com/Ga5xaI
http://r.ebay.com/k9tGkA
http://r.ebay.com/L0xB4e
http://r.ebay.com/TWNtAW
http://r.ebay.com/BmtLRp
http://r.ebay.com/JAlJO0
http://r.ebay.com/SgrWzs
 Filesize:  8.14 KB
 Viewed:  4093 Time(s)
DUBmatze
PostPosted: Fri Jun 27, 2014 4:49 am    Post subject: Re: Transformer for Balanced to Unbalanced Adapter?
hello,
if you use a short cable you can just connect the Pin 2 of the xlr to the tip and Pin 1 to the sleeve of a 1/4 TS/TRS. and you have a connect. I think the easyest way to do it with a transformer is buy a passive DI Box (it exact that what you posted).
http://www.thomann.de/gb/millenium_die_dibox_passiv.htm
~10Euro
very cool overview!!
johnyradio
PostPosted: Fri Jun 27, 2014 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thx!
trying to DIY.
