Wren latest version - 2025.4.10.0
Page 2 of 11 [263 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 9, 10, 11 Next
Audio files: 317
PostPosted: Tue Jun 03, 2014 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added a file render option.
Audio files: 317
PostPosted: Wed Jun 04, 2014 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Changed render mode, and fixed a filter stability issue.
start of thread
wren page
Audio files: 317
PostPosted: Sat Aug 23, 2014 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Had some unreleased stuff and some new things . thought it to be time for a new release.
Mainly the Euclidean Rhythms and the CSV data player, some changes on existing modules too.
Audio files: 317
PostPosted: Sun Oct 19, 2014 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Some bug fixes, some new modules for version 2014.10.19.0 - see first post in thread for more info.
Audio files: 317
PostPosted: Sun Dec 14, 2014 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
WREN is about one year old now!
Current version is 2014.12.12.0
http://bluehell.electro-music.com/wren/forums.html
I've added PortAudio support, this makes the program much nicer to work with.
When PortAudio is used the latencies are lower, the CPU load is lower too (for a CPU with more than one core), the audio artifacts on editing or touching the program's title bar are gone too.
Multi channel works when ASIO is being used, for me at least (with Asio4all and the RME ASIO drivers, although I had to install Asio4All to make the RME ASIO work ... ).
Device selection still works so so and it is needed occasionally to exit WREN and to restart it to get it all working, but once set and working on a next startup it is all OK. I'm working on that still.
The next release will have a button to call up the ASIO control panel. As of yet I'm not happy with how I implemented that, but soon ...
There were some more changes, for one it looks better and you can color modules, and there are 101 module types available now.
Also tons of stability issues were ironed out.
edit : url update.
Audio files: 317
PostPosted: Sun Dec 14, 2014 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a little demo track.
This is a WREN noodle using some samples, one of them spoken by Bubzy from here.
There is a little external echo and reverb on this one.
bubzy wrote:
I am misty among the spirits
Quite scary above the mud
We converse with arid whorls over the vapors
Awake! The King will go
All sexy beside the land
I seduce musty bugs below the slime
Tighten up your wig! The Knight gets weird
You grasp colorful virgins under the mud
Awaken! The Knave will come
translucent intangible
seeing the light
a phone ringing somewhere
With what regrets
my friend
seek shelter
trying to remember
2014-12-15--Blue Hell and Bubzy--we grab colorful virgins under the mud.mp3
Blue Hell and Bubzy - we grab colorful virgins under the mud
 Filename:  2014-12-15--Blue Hell and Bubzy--we grab colorful virgins under the mud.mp3
 Filesize:  20.75 MB
 Downloaded:  2326 Time(s)
bubzy
Audio files: 64
PostPosted: Sun Dec 14, 2014 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
i like it ! Very Happy
_Richard_ Smile
Audio files: 317
PostPosted: Sun Dec 14, 2014 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool thanks!
BobTheDog
PostPosted: Thu Dec 18, 2014 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
101 modules Shocked
I might have to to install this on a VM now it is it's birthday.
Audio files: 317
PostPosted: Sat Dec 20, 2014 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. I had some fuckups Confused
Wren would not start without an ini file present and it would not store the channel selections properly either .. this got fixed in the 2014.12.20.1 release currently present at http://bluehell.electro-music.com/wren/forums.html
Sorry for for that .. but hey .. you never tried it anyway, or you would have told me about it Laughing
edit : url update.
Audio files: 317
PostPosted: Sat Dec 20, 2014 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
You'll need to find sweet spots a bit for buffer sizes ( the default settings are not usable, usually).
When using PortAudio keep them shortish ... like 64 .. 512. For ASIO the size from the ASIO driver will be used, so pop up the ASIO control panel for that. For my RME thingie I needed to set 4096 and it still sucked .. so dunno about ASIO.
Latency will will be almost bearable, well for me it still sucks, but got a user quoting 4ms.
When using legacy mode use longish buffers, like 16384 .. 65536. latency will be awful .. like 1 .. 2s.
I never got it better than about 30ms here, MIDI to sound that is, 60ms on audio in to audio out.
I had high hopes on using PortAudio .. and yes it is like 20 or 30 times faster than legacy mode, but it is not quite like the 'couple of ms hey how bad can it be' idea I had in mind.
So .. might be usable for MIDI control, but as an FX device its still not nice .. yeah .. I played guitar trough it Confused
Maybe WASAPI exclusive mode will help, did not try that yet.
Audio files: 317
PostPosted: Sat Dec 20, 2014 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
But hey .. it did
for me Cool
Audio files: 317
PostPosted: Mon Dec 29, 2014 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added a basic vocoder, basically :: http://bluehell.electro-music.com/wren/forums.html#dones
edit : url update.
Audio files: 317
PostPosted: Sat Jan 03, 2015 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version : http://bluehell.electro-music.com/wren/forums.html#dones
edit : url update.
forcefielder
PostPosted: Mon Jan 05, 2015 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
that demo track sounds great
Audio files: 317
PostPosted: Tue Jan 06, 2015 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you :-)
Audio files: 317
PostPosted: Sun Jan 18, 2015 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Some works on the sequencers .. chaining works better with the new SeqSeq module, step interpolation and reversal for chained sequences.
Added Talkie a retro style speech thingie with a list of about 1200 words it can say. You could make your own word lists for it too it seems, but I did not try that myself.
Also made a fresh source code release.
edit : url update.
Audio files: 317
PostPosted: Thu Jan 22, 2015 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mostly the audio rate oscillators are band limited now. Some other small changes too, like Talkie got expo FM control and got a bit easier to control.
Anyways, tri, saw and square oscs are usable now, with a lot less aliasing. Anti-aliasing works on PM, FM and hard sync modes too.
edit : url update.
Audio files: 317
PostPosted: Wed Feb 25, 2015 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some bug fixes, a clocked delay module, sped up some stuff ...
edit : url update.
Audio files: 317
PostPosted: Sat Apr 25, 2015 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.4.25.0 was just posted .. changes since 2015.2.26.0 :
  • Logic selector module added
  • Convoder module added
  • Forth interpreter added - experimental only
  • Euclidean scale module added
  • Pattern module added
  • Fixed MIDI modules
  • New bitmaps for knobs, so they look a bit nicer on colored backgrounds
  • Made peak and valey indiccators on VU meters
  • Fixed the global tuning parameters
  • Programmable Frequency divider added
  • DigiMux and DigiDemux modules added, DigiDemux has a built in hold mode
  • Changed 2to1 switcch to be 2to2 - it swaps the channels on a switch
  • FreeVerb got some work to make it sound a bit better
  • Made a version checker - available trough help menu or about page
  • Added a new reverb module based on GVerb
  • Various small bugs fixed
  • Source code released for 2015.4.25.0 too
See http://bluehell.electro-music.com/wren/forums.html#dones for details and downloads.
edit : url update.
Audio files: 317
PostPosted: Sun May 10, 2015 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.5.10.0
Please read http://bluehell.electro-music.com/wren/forums.html#changes for changes.
A recent screen shot:
edit : url update.
JLS
G2 patch files: 316
PostPosted: Mon May 11, 2015 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan
New version 2015.5.10.0 not working on WinXP SP3 32bit and Win7 Pro 64bit
After run wren.exe generated error window "Access violation at adress 0081B75 in module wren.exe."
Sorry my bad english
Kamil
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
Audio files: 317
PostPosted: Mon May 11, 2015 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok .. at start up? or with a particular patch?
JLS
G2 patch files: 316
PostPosted: Mon May 11, 2015 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
startup
Audio files: 317
PostPosted: Mon May 11, 2015 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok .. is it related to PortAudio?
please see http://electro-music.com/forum/topic-64254.html for details about that.
