 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
non resonating benjolin filter(solved)
Post new topic   Reply to topic Moderators: Rob
Page 1 of 1 [2 Posts]
thorncore
PostPosted: Fri Jun 05, 2015 10:42 am    Post subject: non resonating benjolin filter(solved) Reply with quote  Mark this post and the followings unread
A friend and I have made a couple of Benjolin boards and are having issues with both builds.
On the first build it seems to Rungle correctly,both oscs respond to CV input.
The Filter Cutoff if working as expected as are the modulators normaled to it.
The Resonance Pot has little effect other than to cut the sound off completely when turn CCW past about 12o'clock.
On the second build it is evident the filter is working properly,very nice squelchy resonance but the Rungler seems to have little effect over the filter modulation when applied.
Indeed the Rungler activity seems much more pronounced in the first non resonating build.
Between the two I have a functioning benjolin I guess.Smile
thorncore
PostPosted: Sat Jun 06, 2015 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
hopefully solved....
my usually very reliable resistor supplier sent me 10R resistors instead of 510R....
