 Forum index » DIY Hardware and Software » The Repair Shop
Replacing missing key caps
Page 1 of 1 [2 Posts]
Dan Lavin
Audio files: 21
PostPosted: Fri Jun 12, 2015 3:09 pm    Post subject: Replacing missing key caps
Subject description: a cheap alternative to 3D printing
I just finishing restoring a Roland AX-7 keytar. Unfortunately the previous owner had abused the thing so much he lost a couple of the momentary switch knobs. I knew Roland would want some outrageous amount for original replacements so I decided to DIY them.
Basically I created molds with molding clay found at the hobby store. I then pounded a good knob into the clay and pulled it out, leaving a perfect cavity. I then filled it with hot glue. Make sure you pump the glue in like soft serve ice cream to get rid of air pockets. Let it cool, then pull out your copy. Trim with razor knife and paint per your choice of colors.
use a hammer to plug in the part to clone
 Filesize:  1.61 MB
 Viewed:  306 Time(s)
clay with cavities
 Filesize:  1.64 MB
 Viewed:  304 Time(s)
original with copy
 Filesize:  1.66 MB
 Viewed:  331 Time(s)
Synth DIY since 1977!
PostPosted: Fri Jun 12, 2015 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hot glue! great idea :-)
