What passive modules can I make???
Page 3 of 3 [54 Posts]
Goto page: Previous 1, 2, 3
LektroiD
PostPosted: Sat Jun 19, 2010 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm presuming the caps around the 500K pot are non polarised, as opposed to the switched ones (which have polarity markings)?
LektroiD
jnuaury
Audio files: 9
PostPosted: Sun Jun 20, 2010 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
the markings on the "schematic" are a bit inconsistent in the way they are drawn. any capacitor gives a phase shift. i used non-polarized for all the caps. im pretty sure you can use polarized for any cap too, if you make sure the - side goes to ground
az/gde
Flickr
YouTube
sirsicksik
PostPosted: Sun Sep 13, 2015 10:19 pm    Post subject: Passive vactrol filter not working yet
Subject description: well, it ain't working yet.. trying to find out why.
I've tried to make the vactrol controlled filter as I need some LPG's/VCA's.
Though there ain't nothing coming out yet (no magic smoke either).
I've been using these vactrols:
http://store.synthrotek.com/Vactrol
Though I think it probably has to do with the ground-connection.
Do I need to connect the ground of the audio input to the ground of the audio output too? Or is this covered with the ground-connection to the vactrol input through the capacitor?
[img]https://www.facebook.com/photo.php?fbid=10156037292620626&set=p.10156037292620626&type=1[/img][/img]
sirsicksik
PostPosted: Sun Sep 13, 2015 10:24 pm    Post subject: ps. Reply with quote  Mark this post and the followings unread
ps.
1. how should the capacitor be connected?
I've connected the minus pin to the ground of the output.
2. I've made a voltage divider using 2 180ohm resistors before the vactrol:
in series between positive and ground, then the vactrol connected in the middle with the cathode (shown with a dot)
3. the ground of the output is ONLY connected to the capacitors (I used two, with positive pins connected to a switch and both negative pins to the ground, so I can select different caps)
