PCB offer: Thomas Henry's CMOS ADSR (blinkin' lights)
Page 3 of 3 [54 Posts]
Goto page: Previous 1, 2, 3
infraxpert
PostPosted: Wed Feb 19, 2014 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you consider to run again?
or do you have a waiting list for this project?
PostPosted: Wed Feb 19, 2014 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
no. not in near future.
nevertheless, i am working on a dual transient generator (loopable, invertable, with VCAs and voltage controlled offset).
AlasdairMoons
PostPosted: Fri Jul 01, 2016 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
would it be possible to add CVin to A D S and R?
I would like to control these with f.e. a sequencer
Thanks in advance
my Music-Channel:
my Facebook:
PostPosted: Fri Jul 01, 2016 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
for Attack i think it wouls be rather easy. just mix the pots voltage with an external voltage.
for the other stages i don't see an easy solution. one could maybe mix the Decay pots output voltage with an external voltage, however, the decay is dependent from the sustain level anyways.
maybe having Attack and Decay under voltage control would be sufficient?
