Opl3 player module
Page 1 of 1 [9 Posts]
PostPosted: Sun Jan 29, 2017 6:35 am    Post subject: Opl3 player module
Subject description: a synth for my synth
I'm working on an OPL3 player module.
Started ordering a few YMF262 Yamaha FM chips, which have been used in a lot of synthesizers in the 80ties. Along with these YMF262 I ordered some DAC chips YAC512.
The module is far from ready, but the basics work, I can select from 128 instruments and have them played frm the internal midi and gate.
Todo is to have the ext. midi to work so I can play from a polyphone keyboard or ext. sequencer.
Also I want to be able to change the instrument parameters so I can fiddle around with the sound of the instruments.
Here a link to my OPL3 player:
https://youtu.be/-WvVVEAcwWw
 Filesize:  841.41 KB
 Viewed:  909 Time(s)
 Filesize:  1.16 MB
 Viewed:  1031 Time(s)
PostPosted: Mon Feb 06, 2017 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have been playing around with this new module. As for the hardware it's nearly finished, but the software is another story Rolling Eyes
Originally I put a MCP6044 quad opamp in this module, but it sounded terribly.
I didn't realized that an opamp could make such a difference in a simple circuit like the output circuit of this module.
So I made an audio file with three opamps: first the TLC274, the MCP6044 and last one the MCP6284.
The MCP6044 (that's the most "expensive" of the three 1.75€) is the worst qua sound, while the MCP6284 (the cheapest, 1,39€) sounds the best to me...
Also I am asked for the diagram of this module, so I added it as well.
 Filesize:  86.27 KB
 Viewed:  1920 Time(s)
three_opamps.wav
first 20 sec is a TLC274, next 20 sec is a MCP6044 and last 20 sec is a MCP6284 output stage
 Filename:  three_opamps.wav
 Filesize:  5.39 MB
 Downloaded:  1456 Time(s)
OP3 player.pdf
 Filename:  OP3 player.pdf
 Filesize:  169.44 KB
 Downloaded:  1568 Time(s)
lazarusr
PostPosted: Mon May 08, 2017 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Really nice project. A while back, I made a 'sound card' for the BBC Micro (British 8-bit 6502 computer from the '80s) based on the YM3812 (OPL2). Details here: https://github.com/lazarusr/BeebOPL and some sample tunes here: https://soundcloud.com/user-469563483/sets/beebopl-1
I am now working on a similar project using the YMF262. Although, not going as smoothly as I had hoped.
I'd love to see any updates on your OPL3 module. Also, would you be prepared to share your Arduino source code?
PostPosted: Tue Sep 08, 2020 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
IT's POLYPHONIC (6 voices)
my synth
Audio files: 321
PostPosted: Tue Sep 08, 2020 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
cool!
PostPosted: Sat Dec 05, 2020 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Second iteration, this time I used a Stm32 Blue Pill.
edit: corrected an omission in the Schematic
 Filesize:  975.01 KB
 Viewed:  526 Time(s)
 Filesize:  3.17 MB
 Viewed:  573 Time(s)
 Filesize:  59.69 KB
 Viewed:  691 Time(s)
OPL3 player.pdf
 Filename:  OPL3 player.pdf
 Filesize:  397.79 KB
 Downloaded:  588 Time(s)
my synth
PostPosted: Sat Dec 05, 2020 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
my synth
PostPosted: Wed Apr 14, 2021 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Small changes made.
Now the clock frequency for the YMF262 is generated by the BluePill.
YMF262_Euro.zip
Zip file with the Arduino code for the BluePill STM32F103C
 Filename:  YMF262_Euro.zip
 Filesize:  9.48 KB
 Downloaded:  513 Time(s)
OPL3 player BP clock.pdf
new schematic with clock for YMF262 provided by the BluePill STM32F103C
 Filename:  OPL3 player BP clock.pdf
 Filesize:  397.73 KB
 Downloaded:  567 Time(s)
my synth
RykAntoniuk
PostPosted: Fri Jul 15, 2022 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa! Well done!
