1984, a sequencer
Page 1 of 1 [11 Posts]
PostPosted: Sun Dec 03, 2017 12:08 pm    Post subject: 1984, a sequencer
Subject description: based on the M185 sequencer made by Ryk
When I first saw the Metropolis made by Intellijel, I immediately liked the idea of the repetitions set by the slide switch and after watching the Youtube video I started to search if there was anything about the origin of the Metropolis, and behold: It was on this very forum where the M-185 made by Ryk was presented by RYK himself!
The Metropolis was a bit to complex to my idea so I went for a more minimalistic approach, where I could use an Arduino.
Now the first part is working, I have 8 slide pots for frequency CV out, 8 thumb-wheels so I can choose between 0 and 9 repetitions for each step.
U1 is an analog multiplexer/demultiplexer where the potentiometer is chosen that goes to a certain step. U2 is a BCD to decimal converter where the selected output is low while the non-selected outputs are all high.
The LED's connected to the outputs of U2 are the LED's mounted in the sliders of the pots, so you can immediately see which step (potmeter) is active.
U3 is again a BCD to decimal converter where the outputs are connected to the commons of the 8 thumb wheel switches to select which thumb wheel switch is active.
Proof of concept:
https://youtu.be/uXZbiiASfTs
 Filesize:  59.99 KB
 Viewed:  1175 Time(s)
my synth
gabbagabi
PostPosted: Wed Dec 06, 2017 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
and well done like always.
For what and where i have to search for these beautifull sliders u use?
cheers, gabba
PostPosted: Thu Dec 07, 2017 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank You, and this is only the first part.
Next will be the 4 position switches for the gate modes (no gate, a gate for every step, one gate at the start of the repetitions per channel, and a long gate covering all the repetitions in one channel). And the on/off switches for the glide.
After that more controls and outputs, still not sure what right now.
I bought the sliders HERE but I have noticed that they are not the best quality, one failed while soldered to the perfboard Shocked so it's best to test them before mounting.
my synth
gabbagabi
PostPosted: Thu Dec 07, 2017 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, i see .
they are looking better in your video then on alibaba.
Cool
the rest sounds like a never-ending-story,
but our whole sdiy is a never-ending-story,
so everyting normal here
Smile
Sebo
PostPosted: Fri Dec 08, 2017 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, i will follow this post closely Smile
Sebo
My Music:
PostPosted: Sat Dec 09, 2017 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I need a lot more outputs as available on the Arduino I used. Therefore I made this small circuit that gave me an additional 16 digital outputs.
They will be used for gates, LED's etc.
So I connected two 74HC595 in series (the serial in from the first 74HC595 is connected to the MOSI of the Arduino, while its serial output goes to the serial input of the second one).
The program settings in the Arduino code for this circuit are:
DDRB = (1<<DDB2)|(1<<DDB3)|(1<<DDB5);
// PB5 (SCK) = Out
// PB3 (MOSI) = Out
// PB2 (~SS) = Out
// SPI MODE 0 -Init
SPCR = (1<<SPE) // SPI enable
|(1<<MSTR) //master mode
|(0<<CPOL) //setup faling
|(0<<CPHA) //sample rising
|(0<<SPR0)
|(0<<SPR1);//Fosc div. 4
SPSR = (1<<SPI2X); //Double speed bit
Writing to the 74HC595 goes like this:
void send_to_parallel (uint8_t byte_one, uint8_t byte_two)
PORTB&=~(1<<PB2); // drive SS low
SPDR = (byte_one); // send Byte
while ( !(SPSR & (1<<SPIF))) {};// ready?
SPDR = (byte_two); // send next Byte
PORTB|=(1<<PB2); // drive SS high again
and for the timing diagram I used:
while (1)
for (n=0;n<8;n++)
send_to_parallel(n,n);
As you can see in the timing picture it takes about 4.7 uSec to write a 16 bit word to this circuit, not too bad.
But: I have placed the 74HC595 close to the Arduino and have a 100NF cap close to the power connections of these chips.
Now I have used 2 74HC595's in this circuit, but you may add as much as you need, you just have to add more data to be sent.
Schematics for the to parallel section
 Filesize:  45.01 KB
 Viewed:  848 Time(s)
Timing measured with Saleae Logic 1.1.15 (at 24MHz, 5M Samples)
 Filesize:  136.19 KB
 Viewed:  879 Time(s)
my synth
PostPosted: Sat Dec 09, 2017 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have added 4 slide switches for the gate control. Now I can choose for each channel what kind of gate I want: no gate (duh..), only the first repetition has a gate, every repetition has a gate and a gate covering all repetitions.
Here a short demo of the switches: https://youtu.be/QPUI9k5kWKM
The 8 switches with their BCD to DEC decoder.
 Filesize:  40.54 KB
 Viewed:  946 Time(s)
my synth
PostPosted: Wed Dec 13, 2017 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I am working on the switches, used to switch the glide on/off for each step of the sequencer.
When pressing the switch there will be a short pulse going into the clock, the 74LS74 has it's inverted output connected to the D-input, so every time the clock gets a positive going pulse the output will change it state, turning the push-buttons into on/off switches.
Circuit of the switches used to switch glide per step on/off, and two switches for run/stop and a reset switch
 Filesize:  115.31 KB
 Viewed:  896 Time(s)
my synth
PostPosted: Sun Dec 24, 2017 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I have added a Glide circuit, by pressing the button once the glide is added to that step, pressing the button again, the glide is off.
In the diagram the GLIDE input is coming from pin 3 of the 74HCT4051 and is 5 volt when a Glide is active during that step. When GLIDE is high, the H11F1 is in its off state, so the 1 Meg R25 potmeter is controlling the Glide amount (1 Meg and 220nF is 1.5 sec max).
FREQ CV is the voltage steps from the 8 slide potmeters.
HERE a youtube link to a demo of the Glide.
edit: got the digital values of the GLIDE mixed-up
The Glide Schematic
 Filesize:  64.74 KB
 Viewed:  836 Time(s)
my synth
Audio files: 316
PostPosted: Wed Apr 29, 2020 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Righto .. so why did it take me over two years to pick up on these ideas Laughing
Not to mention that the original ... was even longer ago Shocked
Anyways .. it is very nice! (and am implementing some of it now) Cool
Alfredo
PostPosted: Tue Dec 01, 2020 12:03 pm    Post subject: 1984 sequencer Reply with quote  Mark this post and the followings unread
Fantastic work Grumble, congratulations! I'm following this post from time to time, any progress? Will be very happy to build one if you share the project!
Best regards!
