<on air> Cancelled due to equipment failure - Sorry Chez Mosc
Arduino controlled oscillator
Page 1 of 2 [38 Posts]
petegaggs
PostPosted: Sat Jan 20, 2018 8:36 am    Post subject: Arduino controlled oscillator
Subject description: analogue sawtooth oscillator, with MIDI control
Here is my latest project. It's an oscillator controlled by an arduino.
This is a novel approach - it's a hybrid design, with a standard op-amp integrator to generate a sawtooth much like other analogue oscillator designs.
However, the reset of the integrator comes from the microcontroller, this avoids needing any tempco, matched pairs, calibration etc.
I use the 16 bit timer to generate a square wave of the correct frequency. The rising edge of this will reset the integrator.
So as well as a sawtooth, there is a square wave available as well, I'm not using this yet. If I were to use this, I would suggest buffering with an opamp before taking it off-board.
The integrator drive comes from an SPI DAC. The exponential conversion is done in software by lookup table. The integrator drive level does not need to be precise, any error here will result in a small change of amplitude of the sawtooth, rather than a frequency error, which would be the case with traditional oscillator circuits.
The sawtooth is about 4V pk-pk, and the design works over a 7 octave range.
Other features:
MIDI control
powered from +9V supply (I have a local inverter to generate -9V for the op-amp).
Nice an simple, not too many parts.
I used an Arduino nano in my prototype, since that was what I had to hand, but it was originally going to be a pro mini 5V 16MHz.
Note that you need the arduino MIDI library installed. Also the timer is used directly, so it won't work on all Arduinos. It will work on any '328p based hardware.
source code and other stuff is here:
https://github.com/petegaggs/MIDI-controlled-oscillator
my prototype
 Filesize:  974.01 KB
 Viewed:  985 Time(s)
MIDI-controlled-oscillator.pdf
 Filename:  MIDI-controlled-oscillator.pdf
 Filesize:  54.1 KB
 Downloaded:  1271 Time(s)
PostPosted: Sat Jan 20, 2018 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I have been meaning to test this for a while, but I never got around to it. From the sounds of it, what you have created is actually a DCO. You should also adjust the voltage so that the higher frequencies do not have a lower amplitude.
JacobWatters.com
PostPosted: Sun Jan 21, 2018 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
In the low frequencies I don't see any problems, but how accurate is it in the higher audio range?
my synth
petegaggs
PostPosted: Sun Jan 21, 2018 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
That's actually what happens, there are 2 lookup tables, one for timer to get the frequency, one one for the SPI DAC that sets the integrator drive.
The DAC voltage is about 30mV at the bottom end (midi note 21) rising to 5V at the top (midi note 108).
There's a spreadsheet in the github repository showing how it's all worked out.
petegaggs
PostPosted: Sun Jan 21, 2018 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right, it does get less accurate for higher frequencies, but it's still OK.
the highest note is note 108, corresponding to 4186Hz, here the timer value is 239 decimal, so the precision of the timer is about 0.5% at this point.
PostPosted: Sun Jan 21, 2018 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool Smile
JacobWatters.com
petegaggs
PostPosted: Sun Jan 21, 2018 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cynosure wrote:
Very cool Smile
thanks!
PostPosted: Sun Jan 21, 2018 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice project! Very Happy
my synth
LFLab
PostPosted: Mon Jan 22, 2018 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, so a DCO? Interesting!
PostPosted: Mon Jan 22, 2018 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
it’s a new breed: DCAO (digital controlled analog oscillator) Very Happy
Drawback is that it plays a fixed maximum number of frequencies, due to the limit of the size of the two lookup tables.
Maybe it is possible to have the Arduino calculate the two values, or is it getting to slow doing it like this?
my synth
Sebo
PostPosted: Tue Jan 23, 2018 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I've started to build one of these:
http://www.russellmcc.com/posts/2013-12-01-DCO.html
But never finished.
I think is same concept.
Sebo
My Music:
petegaggs
PostPosted: Mon Feb 12, 2018 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking about that, I think it should be possible to calculate it on the fly, I might to try adapt it to voltage control using the ADC
petegaggs
PostPosted: Mon Feb 12, 2018 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
But never finished.
Interesting, it does seem to be essentially the same thing
petegaggs
PostPosted: Thu Feb 15, 2018 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have updated the software.
Now the values are calculated on the fly in software instead of lookup tables.
This allowed me to add midi pitchbend support, and also analogue control voltage to modulate the pitch. This is intended for LFO or envelope generator to modulate the pitch.
I experimented with a pure V/octave control mode, this didn't work very well, it seems to be a limitation of the arduino ADC which is not quite up to it. There is a bit of non-linearity and it was only usable over a couple of octaves.
I think that with a decent external SPI ADC it might work better.
oscillator test.mp3
Here is a recording of me testing it, showing off the midi pitch bend and analogue pitch adjustment. The latter sounds smoother. The midi pitch bend is a bit granular, this is down my controller keyboard.
 Filename:  oscillator test.mp3
 Filesize:  907.75 KB
 Downloaded:  905 Time(s)
Sebo
PostPosted: Fri Feb 16, 2018 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I did several modules in Arduino using it's ADCs as 1V/Oct input and I could get 5 octaves of decent tracking... Always using look up tables.
Sebo
My Music:
PostPosted: Fri Feb 16, 2018 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do you use tables and still implement pitch-shift?
my synth
Sebo
PostPosted: Fri Feb 16, 2018 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I interpolate the tables...
Sebo
My Music:
petegaggs
PostPosted: Sat Feb 17, 2018 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, on second thoughts the arduino ADC is not bad, I did a quick characterization using the AnalogReadSerial sketch, and it is better than I had thought.
I think it should be good enough for a 1V/octave control, but you would need a pretty precise 5V supply (or VREF at least). I think I as getting poor results due to my 5V supply being slightly < 5V
quick characterisation of arduino ADC
 Filesize:  22.41 KB
 Viewed:  607 Time(s)
synthjakk
PostPosted: Tue Mar 13, 2018 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly the kind of project that I want to try. Apologies if this is a stupid question, what is the purpose of the LMC7660INNOPB Voltage converter? and why is'nt it or the 78LO5 connected to the rest of the circuit?
I have ordered the parts and want to build this project as a learning experience! Any update on the gate implementation?
petegaggs
PostPosted: Tue Mar 13, 2018 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi synthjakk,
The 7660 is used to generate a -9V supply from a +9V supply.
I used it because I wanted to power the whole thing from a single 9V supply. If you already have a negative supply rail available, you can leave this and the associated parts out.
I included a 7805 regulator to provide 5V power supply, this is needed by the arduino, the DAC and a few other things. As I've drawn it, this is providing 5V power in to the VCC pin of the arduino. Alternatively, you can connect 9V to the RAW pin of the arduino and the arduino's built in regulator will give 5V out instead (the VCC pin can be input or output). Ensure you do one or the other not both.
For the GATE output, the software is already driving it, I would suggest including a 1k series resistor and connect it to a socket to drive an envelope generator.
I hope your build goes well.
synthjakk
PostPosted: Fri Mar 16, 2018 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh I see, that makes A lot more sense! Regarding the code, you mention that the value 0.97783686 is in the attached spread sheet, however I can't seem to find this value anywhere. What is its purpose?
Also, what does the 1000000.0 and the -1 represent here?
uint16_t timerSetting = round((1000000.0 / freqHz)-1.0);
My parts arrived today so I will upload a video once it is all working properly! I want to try and fully understand the code to help comprehend the project Smile
petegaggs
PostPosted: Fri Mar 16, 2018 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I forgot to update the spreadsheet after my last changes, it's there in the git repository now. So originally, I worked out the values for timer and DAC in advance in a spreadsheet for each midi note. This is now changed so the arduino software calculates them itself (in function updateNotePitch), this allows analogue voltage control to be used, and pitch bend.
If you look at the sheet called 'voltage control' you'll see how it works. The constant DAC_MULTIPLIER is a function of
a) desired ramp peak voltage
b) integrator R
c) integrator C
d) DAC bit resolution
e) DAC full scale voltage
TBH, it doesn't really need to be a precise value, 1.0 would probably have been close enough, and would have saved a few cycles, however having this constant does allow the above parameters to be changed about.
We have to multiply by one million because freqHz is a floating point number representing the frequency in Hz, and the timer value is effectively in microseconds (the timer is actually running at 2MHz, and the timer period is half the note period)
The -1 is needed because the timer is zero indexed, e.g. loading it with a value of 0 will make the timer run for 1 x timer clock, so to make it exactly right the timer is loaded with the note period in microseconds, minus one.
I look forward to hearing your results!
synthjakk
PostPosted: Sun Mar 18, 2018 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for taking the time to answer, so by analogue voltage control do you mean an external input such as a LFO? I am really only interested in producing a saw tooth for now, so maybe I can factor this out. baby steps lol.
Was the max ramp voltage of 4.442 calculated from the equation V=i*t/C?
How was the DAC multiplier constant equation derived? is there a source that may explain this? I have added an image of what it appears to be on your spreadsheet. I get that 2^12 - 1 is the amount of available steps from the DAC.
I hope you do not mind answering these questions for me. I start building tomorrow!!! Smile
 Filesize:  14.16 KB
 Viewed:  531 Time(s)
petegaggs
PostPosted: Mon Mar 19, 2018 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Synthjakk,
Yes, that's exactly what I had in mind for this. It is reading the analog voltage on pin A0. If you don't need it for now, just comment out this line:
#define ANALOG_CONTROL
If this is not defined, then the analogue control will have no effect.
Yes. That equation is right, V is the level of the ramp after time t, and i will be V_dac/R, since the opamp input is a virtual ground.
I was looking for around 4V or so pk-pk voltage on the ramp waveform. (much more than that you would hit the limit of what the opamp output can swing to, though this depends on the supply used, I'm using +/-9V, so I want to keep it quite small). I chose some component values that gave me about that when the DAC was at max (5V) and the frequency was highest (4186Hz).
I can't remember how I got to 4.442 volts, I think it just worked out that way when I chose some standard values for R & C.
Your equation is correct, and that is how I derived it in the spreadheet. However now I come to think about it, there is a simpler way to explain it:
the value we have to send to the DAC is proportional to the frequency, and this constant defines that relationship.
Think of it this way, at the highest supported midi note (108) the frequency is 4186Hz, and the DAC is at full scale, which for a 12bit DAC is 4095 (or hex FFF). 4095/4186=0.978.
No problem at all.
synthjakk
PostPosted: Wed Mar 21, 2018 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you again, you are being very helpful. I have built the circuit and am just waiting for the 5 DIN connector to arrive so that I can test it.
Something that I am trying to work out is the frequency range that is outputted by the microcontroller PWM out. the spread sheet shows a range between say 300 to 30,000 values sent to the timer.
The timer is prescaled from 16Mhz to 2MHz.
So what frequency would the PWM output with the value 300 say ?
