trouby
Posted: Thu Jun 24, 2010 5:00 am Post subject:
Math Trigger Sequencer w/ ALU (for DotCom, curetronic) |
a new gimmick is finished ans contains a 4bit ALU - arithmetical-logical unit - it can do math. 4bit = 16 steps - 1 bar - sequencer.
it has a clock and S/S/Go input, a switch and 16 outs - for each result one.
the ALU has: 2 operands A & B, the function itself get clocked by a counter, the result goes to a line decoder ans trigger converter.
the result is visualized.
cased of the constant values but variant function the result varies in different ways - some combinations has every value of the 4bits but as difference sequence
to trigger percussive sounds - 2 beatboxes in bad condition have to die for external trigger (will be 19" case)
power is curetronic - DotCom can be a place problem:
top & bottom place for mounting is 10mm - not 12,7 for 1/2"...
403.5 KB |
| Viewed: |
802 Time(s) |
479.15 KB |
| Viewed: |
801 Time(s) |
trouby
Posted: Sat Jul 10, 2010 4:49 am Post subject:
i found out some values to keep explicit every value result - 16 different values at 16 steps - each are triggered; mostly at arith. & logical:
13 - 6, 13 - 7, 11 - 4, 11 - 7, 10 - 4, 6 - 4
highest bit seems to be different. |
Rykhaard
Posted: Sat Jul 10, 2010 5:17 am Post subject:
I'm very curious as to what the sequences SOUND like! Any sound clips of them?
How is it operating? PIC / ARM based? |
trouby
Posted: Sat Jul 10, 2010 8:19 am Post subject:
me, too - sound demo not yet - it's like an semi-random sequencer
i need 16 sound generators, esp. 2 beatboxes which i still need 1.
it's an ALU inside, the 74181, and a 4514 line decoder. |
Rykhaard
Posted: Sat Jul 10, 2010 8:35 am Post subject:
| trouby wrote: | me, too - sound demo not yet - it's like an semi-random sequencer
Ohhhp. Leaves me out of building, for the mo' then.
16 sound generators? Could the outputs not be summed, or logically dealt with? Or to a multiplexer? (Or - am I missing the point here? ) Coming back to summing, I think could be gooder. No? |
glacial23
Joined: Apr 30, 2008 Posts: 32 Location: Cleveland, OH
Posted: Tue Jul 13, 2010 11:39 am Post subject:
Oh, very nice! I've been wanting to build something with ALU chips for a while now. I bought some 74181s and 40181s, but haven't quite done anything with them yet.
I thought it would be interesting to have voltage control over the operation (using a 4-bit ADC or something), but just clocking it seems like a good idea too. _________________ glacialcommunications.com |
trouby
MrsWedge
