today> Various Artists NYE concert
ModularSampler Stripboard layout (ISD1820)
Page 1 of 1 [5 Posts]
emiz
PostPosted: Sun Sep 09, 2018 5:23 pm    Post subject: ModularSampler Stripboard layout (ISD1820) Reply with quote  Mark this post and the followings unread
i´ve made a stripboard layout for a ISD1820 based modular sampler i found on the bastl instruments website.
built mine today works fine easy project and a lot of fun.
you can get the isd1820 chip very cheap on amazon.
i added voltage regulator input buffer and out booster.
1st pot is input attenuverter
2nd is pitch cv attenuverter
3rd output booster
for the main pitch i used a 100k fader on the right
feed through and loop are spdt´s
rec trig and gate are momentary buttons.
 Filesize:  409.72 KB
 Viewed:  659 Time(s)
 Filesize:  457.84 KB
 Viewed:  596 Time(s)
 Filesize:  82.37 KB
 Viewed:  838 Time(s)
Heres the original schematic from Bastl Instruments
 Filesize:  40.78 KB
 Viewed:  754 Time(s)
Modular Sampler test.mp3
Simple drumloop adjusting pitch. later the pitch is lfo modulated
 Filename:  Modular Sampler test.mp3
 Filesize:  2 MB
 Downloaded:  748 Time(s)
gabbagabi
PostPosted: Wed Sep 12, 2018 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
didnt know about this chip.
Would be interesting to know what are the lower REC/PLAY timing limits.
I have something like an odd delay in mind, one is recording - one is playing, with filter-feedbackloop?
cu,
emiz
PostPosted: Wed Sep 12, 2018 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
g.gabba wrote:
nice!
cu,
the record time goes up to 20 seconds depending on the resistor or in this case the position of the pitch cv pot during the record. . the sample rate is also affected by this. you get best results in the middle range .
 Filesize:  131.65 KB
 Viewed:  640 Time(s)
PostPosted: Thu Sep 13, 2018 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting -- I've built a Madbean Loophole, which is a stompbox looper that uses the ISD1020AP chip in similar fashion. The ISD1020AP is a bit bigger though -- 28 pin!
How is the audio quality?
emiz
PostPosted: Thu Sep 13, 2018 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
the quality is very noisy. and theres a audible click when you trigger it, but not too bad at all.
