dead simple wave mangler
Page 1 of 1 [12 Posts]
gabbagabi
PostPosted: Mon Sep 17, 2018 10:55 am    Post subject: dead simple wave mangler Reply with quote  Mark this post and the followings unread
hi guys,
After seeing in Ricko´s schematic something that is called "clamp" http://electro-music.com/forum/topic-70330.html,
the friedly little voice in my head have asked: how this would sound? answer: dont know, but i can simulate it for u sugar
i could imagine that buffering the in&outs could make sense
cu
 Filesize:  133.17 KB
 Viewed:  489 Time(s)
 Filesize:  240.88 KB
 Viewed:  505 Time(s)
gasboss775
PostPosted: Mon Sep 17, 2018 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice, will need totry it on the breadboard soon!
PostPosted: Mon Sep 17, 2018 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
can't go wrong with some unicorn magic dwarf
are the pots wired as voltage dividers (connected to GND) ?
gasboss775
PostPosted: Tue Sep 18, 2018 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
@PHOBoS : I think they are being used as variable resistors here?
gabbagabi
PostPosted: Tue Sep 18, 2018 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
we all need some magic from time to time!
yes they are used as variable resistors here, not as voltage dividers
would love to hear how it worked out on breadboard Smile
PostPosted: Tue Sep 18, 2018 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah ok, thanks guys Very Happy
I think I'll give this a try with some squarewaves as it might be fun for lunetta's. I do think it would be wise to add
an extra resistor in series with the second pot (connected to the base of Q1/Q2) to limit the current a bit.
gabbagabi
PostPosted: Wed Sep 19, 2018 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
when u only use SQR´s i could imagine that a little filtering could pep-up the results
i guess the maximum current here is determinated by R2, so i would also test it with basis-resistor going to zero, may some magic could happen there Smile
 Filesize:  109.56 KB
 Viewed:  498 Time(s)
MapacheRaper
PostPosted: Fri Sep 21, 2018 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I love simple designs.... Could I ask what is a wave mangler?. It seems like a wavefolding slash mixie thinguie...
gabbagabi
PostPosted: Mon Sep 24, 2018 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
well it processes the waves in a rather unpredicted way using raw force, just throw it in and press it, like when they have mangled the sheets back in the days
Smile
kaputtpanzer
Audio files: 15
PostPosted: Mon Sep 24, 2018 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. I love this circuit, it is a weird mix between a VCA, ring mod and wave folder. I tried to simulate it with the falstad circuit app, this circuit spits out some beautiful waves. I attached an audio of the simulation, sorry for the poor quality (recorded it with the audio note function from my tablet) Laughing
I mixed the two outputs with a potentiometer...
 Filesize:  149.22 KB
 Viewed:  420 Time(s)
 Filesize:  158.72 KB
 Viewed:  405 Time(s)
 Filesize:  246.07 KB
 Viewed:  394 Time(s)
saw+triangle.wav
wave mangler:saw and triangle input
 Filename:  saw+triangle.wav
 Filesize:  1.77 MB
 Downloaded:  696 Time(s)
kaputtpanzer
Audio files: 15
PostPosted: Mon Sep 24, 2018 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
... two square waves. Again I apologize for the audio quality Embarassed
squareandsquare.wav
 Filename:  squareandsquare.wav
 Filesize:  2.66 MB
 Downloaded:  631 Time(s)
gabbagabi
PostPosted: Wed Sep 26, 2018 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
cool!
thx for the soundsamples!
iam glad it is something usefull.
and the sound quali wasnt that bad Smile
