A nice and easy compressor to DIY?
Page 1 of 1 [9 Posts]
MapacheRaper
PostPosted: Thu Aug 23, 2018 3:26 pm    Post subject: A nice and easy compressor to DIY? Reply with quote  Mark this post and the followings unread
I don´t see compressors in the typical DIY kits/ markets (Thonk, Modular addict, etc)
Why?
Is there any nice and easy compressor building or PCB to recommend?. Ideally with no valves or esoteric components.
I´d like to go for a 1176 but that toroid transformer seems expensive AF. Could it be replaced with other more economical option?
LFLab
PostPosted: Fri Aug 24, 2018 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
What is your goal?
Most studio projects require specific and often expensive parts and/or are more complex builds with a lot of components.
There are a few modular specific kits/ PCB's and those usually are simpler.
Even simpler are diy guitar pedals of which there are also some compressor projects, usually more "colourful" (ie. more distortion)
vladosh
Audio files: 51
PostPosted: Fri Aug 24, 2018 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
here's two comressor circuits i found and been thinking to make for myself https://burnit.co.uk/sdiy/forums.html?page=boxotrix
http://mnats.net/what_compressor.html
these do have a bit special parts like THAT chip which is bit expensive or the Vactrol in the other
biscuitdough
PostPosted: Sat Aug 25, 2018 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
People seem to like the Hairball kits, but I don't know how much better they are than a production compressor in the same price range.
MapacheRaper
PostPosted: Sun Aug 26, 2018 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
LFLab wrote:
What is your goal?
I guess the goal is getting something good sounding, easy to DIY, funny to DIY eurorackable and economical. Smile But Im open to change this variables if something caches my eye.
After reading quite a bit on the 1176 the idea gets more seductive the more I read. Maybe I should try with a common transformer or even DIY the trafo itself. Will see Wink
MapacheRaper
PostPosted: Sun Aug 26, 2018 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Im checking the hairball site. Thanks!
PostPosted: Wed Sep 19, 2018 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
What are the differences between studio compressors, and guitar pedal compressors?
wmonk
Audio files: 15
PostPosted: Sat Sep 22, 2018 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Input/output impedances and levels. Signal-to-noise ratio needs to be a lot higher in studio equipment. Studio equipment needs to be able to drive lines and needs a balanced output.
Now when you build for synth, you have one big advantage: high signal levels, no need for balanced circuits, and easy input impedance. Smile
Weblog!
MapacheRaper
PostPosted: Wed Oct 03, 2018 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, it´s not DIY but Klark Teknik is cloning all the classic compressors at 200-300€ each Shocked (1176, LA2A and Pultec EQP-1A)
In stock in Thomann and your fav music shops
I haven´t see at audio comparatives yet, but Klark use to have top notch qualities, so I guess It doesn´t make sense anymore to DIY it. At least you want it, sure
