gasboss775
Posted: Tue May 16, 2017 6:40 am Post subject:
PAIA2720-3B VC Bandpass Filter_Augmentations |
I tried out the PAIA 2720-3B VC Bandpass Filter on the breadboard. I wasn't initially that impressed with its range. However I swapped the diode for a red led and drove it from an exponential current source, the result was a great increase in the range of the filter. I also changed the way in which the Q control was implemented, resulting in, in my opinion a more natural control contour.
I also made a second version with a simpler current source using just one NPN transistor. The results were still very impressive.
The most interesting characteristic of these filters is the way they behave when overdriven. With high Q settings, the LED becomes modulated by the very signal that it is controlling and things freak out somewhat, the LED flickers too in response to the large signal swing!
The original is included for comparison.
288.89 KB |
| Viewed: |
1370 Time(s) |
212.14 KB |
| Viewed: |
1313 Time(s) |
11.33 KB |
| Viewed: |
1242 Time(s) |
gasboss775
Posted: Wed May 17, 2017 5:38 am Post subject:
| I tried out the PAiA 2720-3L Lowpass filter. Again it worked better with LEDs instead of diodes and a current source to drive the LEDs. I chained two Lowpass filter sections together to make a 4 pole filter. It was quite good but would really benefit from having a Q / resonance control. I'm going to have to figure out if this can be done. |
gasboss775
gasboss775
Posted: Sun May 21, 2017 3:39 am Post subject:
I was just trying out the circuit from my last post again and it would seem that 68K is a better choice for R12 as it allows the filter to be completely closed.
I suspect that there might need to be a bit of experimentation with some of the resistor values to accommodate different LED's. Specifically, R9 & R12. Last edited by gasboss775 on Sun May 21, 2017 7:15 am; edited 1 time in total |
gasboss775
n.d
Posted: Fri Feb 16, 2018 6:14 pm Post subject:
| Nice work! |
gasboss775
Posted: Fri Mar 09, 2018 12:12 pm Post subject:
Thanks dude.
I have experienced some problems with instability ( it bursts into oscillation ) that seem to be somewhat related to circuit layout ( I've only ever built it on a breadboard )
I did find that putting a 100n ( 0.1uF ) capacitor between the collector or Q2 and ground helped a bit. Does anyone else have any suggestions about making this behave. I was thinking of using either an FET optocoupler or a vactrol instead of the diode to tune the filter in order to avoid the circuit using the same ground as the control signal. |
Fernando
Joined: Dec 30, 2006 Posts: 286 Location: Barcelona & Emporda, Spain
Posted: Mon Aug 27, 2018 11:26 am Post subject:
very nice gasboss!
I always think about trying the most simple PAiA circuits.
Well for the twin T filter (2720-3b) I'd try with a photocell instead of the diode and a circuit to control the LED. Or a real vactrol instead of a DIY one. But DIY you can use a more adequate range for the photocell and have less work fine-tuning it's right resistance range.
There are many schematics for vactrol CV around from other circuits (Buchla LPG, etc.) but I'd try something much simpler first, the simplest possible.
Try this: http://thesquarewaveparade.com/images/VtoR.jpg (second option, with offset)
And read here: http://www.electro-music.com/forum/topic-37628.html _________________ Fer
gasboss775
Posted: Mon Sep 17, 2018 9:26 am Post subject:
| Fernando wrote: | | very nice gasboss! |
Thanks for the complement Fernando!
| Quote: | I always think about trying the most simple PAiA circuits.
And read here: http://www.electro-music.com/forum/topic-37628.html |
I have several vactrols and have been meaning to try them out in this circuit. Using a diode or LED have their own charms due to the distortion generated when the filter is driven with a strong signal. I do like vactrol based filters though, they have a dynamic character of their own. Last edited by gasboss775 on Mon Sep 17, 2018 3:15 pm; edited 1 time in total |
Fernando
Posted: Mon Sep 17, 2018 10:04 am Post subject:
| gasboss775 wrote: | | Using a diode or LED have their own charms due to the distortion generated when the filter is driven with a strong signal.. |
that's interesting
I would try with a chain of Ge diodes then _________________ Fer
gasboss775
Posted: Tue Sep 18, 2018 1:56 am Post subject:
| Yeah, Ge diodes sound like a good idea, never tried them at the time. |
Posted: Tue Sep 18, 2018 10:21 am Post subject:
| My experience of clipping diodes in pedals is that Ge diodes have a "softer" sound than Si diodes. You need a couple in series to match the Fv of silicon, though. |
gasboss775
Posted: Thu Sep 27, 2018 8:56 am Post subject:
| AlanP wrote: | | My experience of clipping diodes in pedals is that Ge diodes have a "softer" sound than Si diodes. You need a couple in series to match the Fv of silicon, though. |
Today I tried Ge diodes with a similar filter circuit and it did sound more agreeable ( less harsh than the Si diode ), I also tried an led but I think it sounded worse than the silicon diode ! |
Fernando
Posted: Mon Oct 01, 2018 10:38 am Post subject:
but in the same position as in the PAiA band pass?
I mean, as the variable resistance to ground at the bottom of the twin T?
| gasboss775 wrote: |
gasboss775
Posted: Wed Oct 03, 2018 3:46 am Post subject:
| Yes the diode was in the same position as with the PAiA circuit. |
Posted: Wed Oct 03, 2018 8:40 am Post subject:
LEDs have a fairly high Fv compared to silicon or Ge, they're pretty harsh in pedals, too translates to high levels before clipping. |
cslammy
Posted: Fri Nov 30, 2018 9:12 am Post subject:
Re: PAIA2720-3B VC Bandpass Filter_Augmentations |
| gasboss775 wrote: |
The original is included for comparison. |
Gasboss, what power are you using for V++ and V--? +/- 15V? _________________ Visit my AUDIODIWHY blog and website |
gasboss775
Posted: Sun Dec 02, 2018 2:26 pm Post subject:
| cslammy wrote: | | gasboss775 wrote: |
Gasboss,j what power are you using for V++ and V--? +/- 15V? |
The circuit works from a single +Ve supply rail +12 to + 15 V, 15 would provide more dynamic range for the signal. |
vladosh
Audio files: 51
Posted: Fri Dec 07, 2018 11:33 am Post subject:
Here's some PCB layout for this ,if that's ok . I didn't made the add-on mixer ,just the last linear response version ,wanna try this version , have built this filter once earlier as the original on 18V ,PCB is 70x100mm
496.74 KB |
| Viewed: |
620 Time(s) |
19.19 KB |
| Viewed: |
605 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
danielfiction
Posted: Wed Jan 09, 2019 12:53 pm Post subject:
notch? |
i'm really interested in this filter. i'm going to build it.
but what about modifying it for "notch", aka, band stop output? how would you go about that?
daniel |
vladosh
Audio files: 51
Posted: Wed Dec 25, 2019 2:13 am Post subject:
really like how this filter sounds ,however i replaced that 47K resistor with 62K and it wouldn't close all the way , it's powered with 15V so thinking to try 82K and see how that goes i even wonder if connecting the freq pot to -V via 47K resistor is better ,nice resonance _________________ http://synthacks.blogspot.com/ шематикс |
vladosh
Audio files: 51
MapacheRaper
Posted: Fri Jan 31, 2020 5:49 pm Post subject:
So a lot of chat on how good it sounds but not a miserable audio demo? C.mon guys...
I would love to build one of these but Im a disaster breadboarding |
cslammy
Posted: Mon Feb 03, 2020 5:18 pm Post subject:
I am terrible at breadboarding/stripboarding as well.
I have created BRD and SCM in eagle, posting it here in zip along w/ gerber
I'll send it off on my next fab and let you know what happens.
Relatively Big board, not a lot of vias, room for jumpers, kludge wires etc.
No ground pour, no fancy stuff.
Warning: doing this while at work--checked it once, think i got it right, but may be mistakes. Passes DRC and ERD checks.
48.53 KB |
| Viewed: |
325 Time(s) |
 Download (listen) |
| Filename: |
4720FILTER-EAGLE.zip |
170.43 KB |
| Downloaded: |
366 Time(s) |
MapacheRaper
Posted: Mon Feb 03, 2020 6:12 pm Post subject:
Great!! That´s exactly the kind of project for your blog. Waiting to read the post
It´s a pity that China is halted, tho. Who knows when they will produce it. I have some PCBs paid, and in the schedule to fab in JLCPCB. Not looking good at the moment...
Whatever, cool project |
