today> Twyndyllyngs Chez Mosc
Eurorack Soundlab
Page 1 of 1 [3 Posts]
Zodiak
PostPosted: Tue Apr 23, 2019 1:25 pm    Post subject: Eurorack Soundlab Reply with quote  Mark this post and the followings unread
This is my SoundLab rehoused as a Eurorack panel.
I have added a few upgrades from the soundlab plus and ultimate, most of which are mounted as various daughter boards.
Total upgrade to +/-12V
LFO: Inverted output on ramp
ARG: Trig level control, inverted output
VCO1: PWM, Triangle out, external sync in, and high frequency compensation
VCO2: Triangle out, external sync in, and high frequency compensation
VCF: Exponential tracking, including high frequency comp
VCA: Exponential tracking.
This is the 3rd incarnation of that board and has been a background project for the past 12 years, but I think that it is almost done now. Apart from the VCO tuning which is picking up noise from the supply rail Smile
 Filesize:  1.97 MB
 Viewed:  354 Time(s)
 Filesize:  3.99 MB
 Viewed:  372 Time(s)
Stephen
www.Rainsbury.Net
ixtern
PostPosted: Wed Apr 24, 2019 12:22 am    Post subject: Re: Eurorack Soundlab Reply with quote  Mark this post and the followings unread
Nice looking set.
If you don't want to pick up noise, connect tuning pots to the +- reference voltages rather (+- 9 to 10V) than to the supply rails. It is easy to get them with TL431 or dedicated ref ICs (78Lxx/79Lxx are not so stable regarding temperature changes).
Zodiak
PostPosted: Wed Apr 24, 2019 7:47 am    Post subject: Re: Eurorack Soundlab Reply with quote  Mark this post and the followings unread
Thanks I was gong to use a pair of those 78/79 100ma devices, but will look at that instead.
Stephen
www.Rainsbury.Net
