ChucK 1.4.0.0 mixes up --in and --out args
Page 1 of 1 [5 Posts]
Acoustic Interloper
Audio files: 89
PostPosted: Sun Jul 29, 2018 7:00 pm    Post subject: ChucK 1.4.0.0 mixes up --in and --out args Reply with quote  Mark this post and the followings unread
I posted this in the ChucK mailing list, thought I should put it here in case anyone tries to use ChucK 1.4.0.0 to steer spatial sound:
Just upgraded my osx upgraded to 10.12.6 from 10.9.x, just installed chuck-1.4.0.0, am writing a new chuck patch. Lots of variables. Two days of debugging later:
chuck-1.4.0.0 is not finding dac.chan(N)s correctly with chuck-1.4.0.0, so I pulled a chuck-1.3.2.0 off of an old mac, and my patch works fine.
This is in a Live -> Soundflower -> ChucK -> MOTU driver signal path, which I took apart a piece at a time. When it looked like ChucK, I turned on verbose mode. When I run this command line with MOTU as my output:
/usr/local/bin/chuck.1.4.0.0 --verbose:10 --out:8 # Note: internal mic is the input, MOTU is output, str8.ck is this:
adc.left => dac.chan(2) ;
adc.right => dac.chan(3) ;
90000::ms => now ;
Nothing goes to the MOTU, and the diagnostics show this:
[chuck]2:SYSTEM): initializing audio I/O...
[chuck]2:SYSTEM): | probing 'real-time' audio subsystem...
[chuck]7:FINE!!): | initializing RtAudio...
[chuck]7:FINE!!): | | trying 8 input 2 output...
[chuck]3:SEVERE): | allocating buffers for 256 x 8 samples...
[chuck]2:SYSTEM): | real-time audio: YES
[chuck]2:SYSTEM): | mode: CALLBACK
[chuck]2:SYSTEM): | sample rate: 44100
[chuck]2:SYSTEM): | buffer size: 256
[chuck]2:SYSTEM): | num buffers: 8
[chuck]2:SYSTEM): | adc: 0 dac: 0
[chuck]2:SYSTEM): | adaptive block processing: 0
[chuck]2:SYSTEM): | channels in: 2 out: 8
Notice the "trying 8 input 2 output..." is wrong. There are symptoms that agree with this. If I increase --in above 2 and just do straight stereo in => out, it starts outputting to chan(0), chan(1), up through chan(N), and N is the --in command line argument.
This older version works fine, sends the mic input pair to the correct dac.chans:
$ ./chuck --version
chuck version: 1.3.2.0 (chimera)
mac os x : intel : 64-bit
http://chuck.cs.princeton.edu/
http://chuck.stanford.edu/
./chuck --verbose:10 --out:8 str8.ck
[chuck]2:SYSTEM): initializing virtual machine...
[chuck]7:FINE!!): | | trying 2 input 8 output...
[chuck]2:SYSTEM): | locking down special objects...
[chuck]2:SYSTEM): | allocating shreduler...
[chuck]10:ALL!!): | adding 'Chuck_Object' (0x100712ff0)...
[chuck]10:ALL!!): | adding 'Chuck_Object' (0x1007130b8)...
[chuck]2:SYSTEM): | allocating messaging buffers...
[chuck]2:SYSTEM): | behavior: HALT
[chuck]2:SYSTEM): | adc: 0 dac: 6
"trying 2 input 8 output..." is correct for 1.3.2.0, but not for 1.4.0.0. Chans are buggy, at least on my mac.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Armand
PostPosted: Thu Oct 31, 2019 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, any update on that? I too have lost a few days on it.
Issue is still there on both OSX 10.14.6 and Windows 10. I get an output on some channels but the wrong ones, in some kind of output modulo input way. There is basically no way of using command-line ChucK with a number of in channels diffferent from out, which is really a shame.
MiniAudicle doesn't have this problem, so I would suppose it's not that hard to fix.
Btw, if anyone knows a good way to declare a bug, I'm listening. I posted it on GitHub before finding this post. It's a really crippling issue. I'm a practicing artist in NYC and was hoping to project some code controlling my modular, which I clearly won't do with miniAudicle. It could introduce chuck to a lot of people. But most interfaces in modular have a different number of ins and outs, and I'm not voiding half my out channels...
Acoustic Interloper
Audio files: 89
PostPosted: Fri Nov 01, 2019 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I never heard back from them and, yes, it's a real PITA. I have been working more with visual digital art when I get time for that, and using Live for music. Used ChucK to generate some audio data for a data analysis course in spring 2018; it didn't require the command line args. I hope to actually get good at using Supercollider when I someday get time, probably when I retire. SC has higher quality ugens (IMHO) and an active developer community. I like ChucK's programming model better, but that goes only so far. Crying or Very sad
Armand
PostPosted: Fri Nov 15, 2019 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, little update. I corrected the bug, the fix is in the master branch now.
True, SC is probably best for sound design. I like ChucK for its, like you say, paradigm and precision. If it works to begin with, I know it will do what I tell it, when I tell it when playing live. I might be wrong, but I figured I'd rather invest my time in that and let the CPUs get a few doublings so that sample-synchronous becomes really important.
Acoustic Interloper
Audio files: 89
PostPosted: Sat Nov 16, 2019 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much! I still love programming in ChucK, and still have plenty of uses for that. Princeton Laptop Orchestra coming to play our planetarium in a few weeks. I am eager to find out what they are using these days. Thanks again.
