Large voltage drop in PSU
Page 1 of 1 [23 Posts]
Gingoism
PostPosted: Thu May 28, 2020 8:22 pm    Post subject: Large voltage drop in PSU Reply with quote  Mark this post and the followings unread
I recently built a power supply based on the MFOS adjustable PSU.
After designing and etching the board, i am experiencing voltage drop of a whopping 600mV (12.4V to 11.8V) under load.The load is a 20 Ohm 10W cement power resistor which drew about 500mA.
I fucked up initially by testing without heatsinks and then to be safe i replaced both regulators and tested with heatsinks installed. The heatsinks were salvaged from broken KRK monitors, which are hefty and dissipated the heat well enough.
The transformer is rated at 36VA CT 15-0-15V.
Input voltage is about 20-21V which ensures there is enough headroom.
So what issues could be causing this significant loss in voltage?
I am thinking of breadboarding the circuit and testing again before i etch the final board 2nd time around, with that said the circuit is straight forward enough..
Update: edited the circuit to include missing wire(in red)
12v_linear_psu_951.pdf
 Filename:  12v_linear_psu_951.pdf
 Filesize:  41.23 KB
 Downloaded:  293 Time(s)
Gingoism
PostPosted: Fri May 29, 2020 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
just to update, after breadboarding and testing the results were better but i think my dvm is just not good enough for accurate readings but here is what i noted :
Load = 20R 10W / 510mA - the voltage actually went up 12.05V to 12.15V
= 12R 10W / 895mA - 12.05 to 12.10V
= 8R 10W / 1100ma - 12.05 to 11.20V
so i think the fault must have been in the design or the etching of the board.
i was also thinking maybe i should add a current limiting circuit to cap the current to below 900mA. Any recoomendations?
PostPosted: Sun May 31, 2020 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I am reading, just so you know you are not screaming into the void.
Not really sure what can be causing it, but it seems to be a little bit higher than I would expect.
Does the input voltage drop under load ?
Gingoism
PostPosted: Sun May 31, 2020 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Phobos, yes on the faulty PSU board the input voltage did drop to about 3-4V, so it hovered around 17-18V. With that said the breadboard circuit is relatively stable up to about 890mA but as you can see under a 1A load i lose about 800mv and input voltage drops from 20V to 17V is that normal for a LM317/337 regulator? I know they can handle up to 1.5A correct?
Gingoism
PostPosted: Sun May 31, 2020 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
also side note i was wondering if i can use this Led driver (i have 2 of these) -
http://www.007swz.com/zsdwzg/products/dianyuan_130278.html
and convert it to a either a 15V or 12V PSU, my question is which method would be better?
1. DC/DC Converter
2. Linear Voltage Regulator
Gingoism
PostPosted: Sun May 31, 2020 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
as for heatsinks i tried 2 different ones. see attached pics
heatsink from krk monitor is about 110cm(L)x60(W)x60(H)
the size of the mosfet heatsink is 42mm(L)×35mm(W)×25.4mm(H)
 Filesize:  38.16 KB
 Viewed:  10981 Time(s)
 Filesize:  1.78 MB
 Viewed:  296 Time(s)
gabbagabi
PostPosted: Tue Jun 02, 2020 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
by just fishing in the dark, i would risk to consider that may transformer is not "strong" enough
PostPosted: Tue Jun 02, 2020 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
just checked the schematic (was that here all along, did I check it before ?!) where did you get the idea of putting a diode between the
output and the adjust input ? There should be a resistor there (240 ohms) or is that only missing in the schematic ?
as for heatsinks as long as you can still touch it without burning your fingers it's ok. If you touch it with a wet finger and it sizzles it's getting too hot.
(note: they can get VERY hot).
Breadboards are probably not the best way to test a supply under load. You need solid connections and also wire gauge can make a difference.
Gingoism
PostPosted: Tue Jun 02, 2020 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi gabba,
That was my initial thought then i tried a a different transformer from that pictured below. this one was 40VA and i got similar results..
 Filesize:  2.29 MB
 Viewed:  294 Time(s)
Gingoism
PostPosted: Tue Jun 02, 2020 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are right phobos, the schematic above is wrong and was edited after the 1st iteration.
the circuit is basically from the datasheet
i simulated the circuit in spice and i was stumped by the results..the circuit performed as expected until i changed the load to 10 ohms and below, the voltage dropped from 12.5V to 10V and the load current flat lined at about 1A and remained the same even when i increased the input voltage to 40V...so im not sure what to make of this. has anyone made a lm3XX PSU with an excess of 1.5A?
 Filesize:  401.74 KB
 Viewed:  281 Time(s)
lm317_Reg_20-Ohm_Load.pdf
 Filename:  lm317_Reg_20-Ohm_Load.pdf
 Filesize:  34.75 KB
 Downloaded:  316 Time(s)
lm317_Reg_10-Ohm_Load.pdf
 Filename:  lm317_Reg_10-Ohm_Load.pdf
 Filesize:  34.96 KB
 Downloaded:  291 Time(s)
gabbagabi
PostPosted: Wed Jun 03, 2020 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i was thinking this:
10 Ohm mean 1,5Amp
your transformer is rated 2x15VA 36W
from my experience that means each side of the transformer is rated 18W.
that means because of RMS and 0,707, you could write the rating as 2x (21,21V @18W)
if you draw now 1,5A out of one --> u are well beyond the power rating
in my opinion u are reaching the theoretical limits if u draw 0,85A Shocked
Gingoism
PostPosted: Wed Jun 03, 2020 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yes gabba that makes sense in theory and also in practice...
explains why it was stable up to the point when the load current was around 0.8-0.9A.
Which now i think is pushing it too much and probably would perform much better with full load at 0.6-0.7A.
PostPosted: Wed Jun 03, 2020 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Still, with the voltage dropping to about 17V it's still more than enough for the LM317 to produce a stable 12V.
So why is the output dropping ?
JovianPyx
Audio files: 224
PostPosted: Wed Jun 03, 2020 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
That is odd PHOBoS, has the DC input to the regulator been checked with a scope (especially while under the load causing a problem)?
Time flies like a banana.
corruptio optimi pessima
Gingoism
PostPosted: Wed Jun 03, 2020 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, not with a scope, ill etch a new board over the weekend and run some tests. What am i to observe with the scope beside the Vin at the regulator? As for transformers i don't have anything higher than 40VA on hand.
JovianPyx
Audio files: 224
PostPosted: Wed Jun 03, 2020 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
If everything is happy, it should be a straight line. However, under some conditions, such as weak transformer or insufficient capacitors, it will be a flat line with dropouts or voltage dips at your mains frequency times 2. This will show up as a lower DC voltage on a DMM. If the dips go low enough, the regulator can drop out. That would also be momentary and would cause the regulator's output to have a DMM measured voltage lower than the spec.
Audio files: 299
PostPosted: Wed Jun 03, 2020 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Flat is a bit optimistic .. pre regulator and under load there will always be ripple .. but, as pointed out by you later on, and to clarify things maybe .. the important thing is:
that the lowest dip should still be sufficiently high to keep the regulator happy .. that is .. some 0.2 to 3 Volts above the desired output voltage
(This depends on the regulator specs, it's a number that will be in the data sheet - I didn't look it up .. but IIRC about 2 Volts for the LM317 family - look it up though when it happens to go below 3 Volts, to make sure it's all okay still).
You can lower the amount of ripple by using larger filter caps .. the big pre regulator - post rectifier electrolytic ones.
Larger ones will increase the inrush current tho, the current that will flow to firstly charge them filter caps .. but this is about a low power PSU so not likely an issue .. but might your rectifier diodes pop out occasionally, that would be the thing causing it .. this can be calculated too .. of course . but you would need some detailed specs of the transformer to be able to - specs usually not available.
Anyways .. just some remarks that popped up here after reading the thread.
JovianPyx
Audio files: 224
PostPosted: Wed Jun 03, 2020 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
My main point was to look at the PSU input (and output) with an oscope. Yes, a straight line is optimistic, but if under a light load, it can be quite straight.
The problem occurs when the dips go below the drop out voltage. Every regulator has one. LDO regulators are "Low Drop Out", but you should find the drop out voltage in the datasheet for your regulator. It's good to keep those dips well above the drop out voltage because the input mains voltage can change. If mains goes down, the dips get closer to the drop out voltage. In my own building, I like to over-design a supply, a bit extra current capacity and good size caps.
Gingoism
PostPosted: Tue Jun 23, 2020 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Took a while to get my stuff in order, but finally did some tests and here are the results:
Vin@Reg= 21.69V @ no load
Vout@Reg= 12.00V
Vin@Reg= 18.8V @ 0.285A
Vout@Reg= 11.95V
Vin@Reg= 17.6V @ 0.550A
Vout@Reg= 11.9V
Vin@Reg= 15.2V @ 1A
Vout@Reg= 11.80V
attached pics from the scope, the post rectifier cap voltage is quite noisy. I believe 10,000uF is big enough?
 Filesize:  198.42 KB
 Viewed:  240 Time(s)
 Filesize:  209.03 KB
 Viewed:  263 Time(s)
 Filesize:  176.55 KB
 Viewed:  253 Time(s)
 Filesize:  219.25 KB
 Viewed:  248 Time(s)
 Filesize:  304.9 KB
 Viewed:  270 Time(s)
JovianPyx
Audio files: 224
PostPosted: Tue Jun 23, 2020 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is definitely more droop than the datasheet specifies, so unless it's damaged, it wouldn't be the LM3xx IC at fault.
PSUs need to transfer rather large amounts of current. To do that efficiently, all of the connections must be very low resistance. It would take only one marginal connection giving a little too much resistance to cause voltage droop. Problems in the Vadj part of the circuit could cause it to inaccurately follow the output and make inaccurate adjustments to the output. If not already done, I'd consider re-flowing all of the solder connections.
Dunno, pretty weird, so I'd suspect something weird.
Gingoism
PostPosted: Tue Jun 23, 2020 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
but the results measured are consistent while on the breadboard and also on the pcb. I do have an identical CT transformer thats 36VA 18-0-18, will give that a try later and if the results are the same what should i look at, that might me causing this behaviour. will also reflow the the connections.
With that said I am already designing another PSU with an LM723 but i do hope to at least figure out why this is happening so i can learn from my mistake.
 Filesize:  3.89 MB
 Viewed:  254 Time(s)
 Filesize:  3.68 MB
 Viewed:  265 Time(s)
JovianPyx
Audio files: 224
PostPosted: Tue Jun 23, 2020 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I looked again at the scope traces. What I noticed is that it seems that under little to no load, there's no in-your-face ripple, but as you increased the load current, there began to appear more and more of a sort of sawtooth. It looks like it might be 50 Hz. I would look also at the regulator's input voltage with a scope, it may be coming within the dropout voltage. What that would mean is a transformer that just can't supply the current needed.
The circuit boards look well made.
Gingoism
PostPosted: Tue Jun 23, 2020 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am thinking the same with regards to the transformer, also it began "whirring" audibly at 1A Shocked .
ok will look at getting a higher rated transformer in the meantime.
