Joined: Feb 04, 2005 Posts: 2872 Location: Nottingham, UK
Audio files: 279
Posted: Wed Sep 23, 2020 5:22 pm Post subject:
I'm unlikely to just pop by chat so it would help if anyone needing help could say so here and say when they are available so we could arrange things _________________ Jez
music | adventures in sound | gear for sale |
Joined: Apr 24, 2009 Posts: 2507 Location: Bristol UK
Audio files: 500
Posted: Wed Sep 23, 2020 7:18 pm Post subject:
Laura Woodswalker needs some help to troubleshoot her setup on Friday at 00:30 GMT - so basically at 1:30am BST Friday.
I've agreed to be there to try and work it out and I understand it if that's too late for European people. _________________ Muied Lumens Sub Forum
Bandcamp |
laura woodswalker
Joined: Oct 06, 2007 Posts: 463 Location: phoenixville pa
Posted: Wed Sep 23, 2020 8:09 pm Post subject:
| robsol wrote: | Laura Woodswalker needs some help to troubleshoot her setup on Friday at 00:30 GMT - so basically at 1:30am BST Friday.
I've agreed to be there to try and work it out and I understand it if that's too late for European people. |
OK wait a sec...I'm in Eastern US...whatever country you're in...pick a time that's convenient for you. I'm not working so I can connect any time during the day. I'm not making you guys stay up till 1:30. pick a time in the evening & it'll be afternoon for me. And let me know!
woodswalker88@gmail.com _________________ The most important gear is the brain behind the instrument. |
Audio files: 279
Posted: Thu Sep 24, 2020 3:46 am Post subject:
I am going to try to be around tonight and tomorrow night from 7-12pm BST, so that's 6-11pm GMT or 2-7pm EDT _________________ Jez
Audio files: 500
Posted: Thu Sep 24, 2020 4:31 am Post subject:
| laura woodswalker wrote: | | robsol wrote: | Laura Woodswalker needs some help to troubleshoot her setup on Friday at 00:30 GMT - so basically at 1:30am BST Friday.
woodswalker88@gmail.com |
Oh I am fine with that, I'm not working either.
I was just thinking more heads are better than two when troubleshooting. _________________ Muied Lumens Sub Forum
Bandcamp |
laura woodswalker
Posted: Thu Sep 24, 2020 6:08 am Post subject:
| robsol wrote: | | laura woodswalker wrote: | | robsol wrote: | Laura Woodswalker needs some help to troubleshoot her setup on Friday at 00:30 GMT - so basically at 1:30am BST Friday.
I was just thinking more heads are better than two when troubleshooting. |
OK I will be here at 3 pm US eastern time today (thursday). _________________ The most important gear is the brain behind the instrument. |
Audio files: 279
Posted: Sat Sep 26, 2020 8:52 am Post subject:
My setup for later
| Description: |
| Filesize: |
66.41 KB |
| Viewed: |
487 Time(s) |
| Description: |
| Filesize: |
55.41 KB |
| Viewed: |
485 Time(s) |
| Description: |
| Filesize: |
65.78 KB |
| Viewed: |
467 Time(s) |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
klangumsetzer
Audio files: 37
Audio files: 500
laura woodswalker
Posted: Sat Sep 26, 2020 4:11 pm Post subject:
recordings |
did you record as you played, or is there a recording automatically created somewhere?
I didn't want to mess with recording in Ableton as we had already had USB problems earlier. _________________ The most important gear is the brain behind the instrument. |
Audio files: 500
Posted: Sat Sep 26, 2020 5:07 pm Post subject:
Re: recordings |
| laura woodswalker wrote: | | did you record as you played, or is there a recording automatically created somewhere? |
I recorded in Reaper, which was also used to stream.
But you can also record in Butt, to wav or mp3 file. I think it's on the last tab in the settings window? _________________ Muied Lumens Sub Forum
Bandcamp |
Posted: Sat Sep 26, 2020 5:12 pm Post subject:
With BUTT you can set it up to automatically record what you stream, you set a format (recording quality) for it on the "Audio" tab of the settings, and then some more settings (like what to record when and where) are on the "Record" tab in the same window.
But I'm using a 2nd computer dedicated to streaming and recording - actually all my audio goes trough that computer.
And then there is PHOBoS who records everything .. usually, and manually. _________________ Jan
Ron Holmes
Joined: Sep 27, 2016 Posts: 46 Location: state college
Audio files: 19
Joined: Mar 28, 2006 Posts: 1452 Location: Kansas City, Mo USA
Joined: Jan 07, 2009 Posts: 1220 Location: Scottish Borders
Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Mon Sep 28, 2020 4:54 pm Post subject:
Good to see you all had fun! (My current work schedule has me sleeping right when this was going on... hopefully I can join in on the next event!) |
klangumsetzer
Audio files: 37
Posted: Mon Sep 28, 2020 10:58 pm Post subject:
Re: recordings |
| robsol wrote: | | laura woodswalker wrote: | | did you record as you played, or is there a recording automatically created somewhere? |
But you can also record in Butt, to wav or mp3 file. I think it's on the last tab in the settings window? |
Hello Laura,
I also use Reaper's ReaCast to stream.
For recording the stream I use this free plugin by Voxengo called Recorder on the masterbus:
https://www.voxengo.com/product/recorder/
Hope this helps!
with kind regards
Eike |
klangumsetzer
Audio files: 37
Posted: Mon Sep 28, 2020 11:00 pm Post subject:
| Skrog Productions wrote: | Hi all , had a great day yesterday listening in to all the great music thanks to all who performed & broom control in switching & chat
Here is the Epicyclus set , thanks for listening in
Dave  |
Dave,
Everytime I listen to this my feet cannot stop moving.
Thank you for your great set!
with kind regards
Eike |
Audio files: 500
Posted: Tue Sep 29, 2020 4:12 am Post subject:
Re: recordings |
| klangumsetzer wrote: | | robsol wrote: | | laura woodswalker wrote: | | did you record as you played, or is there a recording automatically created somewhere? |
Hello Laura,
Hope this helps!
with kind regards
Eike |
You can also record the main output directly in Reaper by pressing Alt+Ctrl+B (bounce/record output to disk). _________________ Muied Lumens Sub Forum
Bandcamp |
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sun Oct 04, 2020 1:27 pm Post subject:
| kkissinger wrote: | Regarding the photo below, this is the current setup. I built a sturdy stand for the modular with a terraced desk shelf for the lower keyboard. Its casters allow me to save floor space because I can roll the instrument against the wall yet can roll it out to service it.
I found a nice 35u rack for my rack equipment (yes, it has casters, too). My effort has been to arrange the equipment into a clean layout that is easy to work and to service.
Next to the laptop computer is an Elektron Octatrack.
Besides the modular synth, I utilized the Kurzweil K2600 and a Casio VZ1 to the left of the Octatrack. I didn't use any loopers this time -- I wanted to see what I could manage without any looping. |
| PHOBoS wrote: | | Here's Kevin Kissinger's wonderful set |
Thanks to PHOBoS for capturing this wonderful performance. Thanks to Kevin for an amazing set (which I missed live--had houseguests) and for all the wonderful details about the current setup (which looks spectacular and very tidy, too) and the gear used in the brilliant performance.
PS: I am familiar with the VZ synth engine and if you are willing to share your patches, would love to use them on my VZ-8m. |
Audio files: 279
Posted: Sun Oct 25, 2020 4:33 pm Post subject:
| MusicMan11712 wrote: |
Wow, thank you for your compliment!
I don't have any new or interesting VZ1 patches to share -- I merely used one of the preset patches (the "Bell Tree"). All the other sounds were from the K2600 and the modular synth.
I kept the VZ1 because, despite the difficulty to program it, it makes some very cool sounds. _________________ -- Kevin
http://kevinkissinger.com |
