Psycho lfo wiring question
Page 1 of 1 [7 Posts]
R_Gol
PostPosted: Fri Oct 30, 2020 7:22 am    Post subject: Psycho lfo wiring question Reply with quote  Mark this post and the followings unread
I need a clarification regarding the unused 40106 pins https://imgur.com/a/EmmwqPY
Is pin 11 & pin 14 wired to Ground, pin 7 to -vee, pin 10 wired to pin 13? pin 12 is left untouched ?
am I reading it the right way?
PostPosted: Fri Oct 30, 2020 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
affirmative
IC1E and IC1F are just unused gates and with CMOS chips you should never leave inputs unconnected. The reason pin 10 is connected
to 13 is probably because it was more convenient with the layout but you could also connect pin 13 to something else.
edit: it looks like on the PCB design those gates are swapped but it works just the same.
R_Gol
PostPosted: Fri Oct 30, 2020 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
affirmative
Thanks. I was mainly unsure about pin 10 & 13. You made it clear.
I have another question regarding combining the psycho lfo(https://sdiy.info/wiki/CGS_psycho_LFO) and half of the utility lfo (https://sdiy.info/wiki/CGS_utility_LFO) at the same stripboard.
While the psycho lfo get its +- 12/15 v after a 33r resistor. the utility lfo get its power after a ferrite bead.
If I would like to combine the two circuits to the same stripbard, meaning both will share the same power, can I just omit the ferrite bead at the utility lfo and provide the utility circuit with the same power as the pyscho?(after the 33r resistor) ?
Is there anything wrong with the above ?
Hope I made MY question clear
Thanks
PostPosted: Fri Oct 30, 2020 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could do that but with circuits like these, which can be a bit noisy on the supply, I would add the beads or another set of resistors.
R_Gol
PostPosted: Fri Oct 30, 2020 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
by adding the beads you mean that the utility lfo will get is power like in the original - meaning after the beads and the psycho lfo will get is power after the resistor, also as in the original ?
PostPosted: Fri Oct 30, 2020 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, this will add some isolation between them reducing the chance of crosstalk.
R_Gol
PostPosted: Sat Oct 31, 2020 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Great. I will do so.
Btw - a 76ohm ferrite bead like the ones you find on tayda https://www.taydaelectronics.com/axial-ferrite-bead-76-ohm.html
are fine for cgs circuits ?
