<on air> Various Artists NYE concert
basic wet / dry for effects circuit
Page 1 of 1 [4 Posts]
floating-water
PostPosted: Tue Dec 08, 2020 4:02 pm    Post subject: basic wet / dry for effects circuit Reply with quote  Mark this post and the followings unread
Apologies of this bores someone but whats the usual protocol for setting up a wet dry knob on a circuit? I have a delay circuit on the breadboard, ive buffered the input, sent it to the delay aswell as to the 1st pin of a potentiometer then the output of the delay to a buffer then to the 3rd pin of potentiometer. Output is from the middle pin of potentiometer. I have a feeling the problem is where the output from the input buffer goes to both the delay and the pot how do you get two outputs from one output? Resistors?
PostPosted: Wed Dec 09, 2020 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, resistors:
 Filesize:  14.16 KB
 Viewed:  276 Time(s)
my synth
floating-water
PostPosted: Wed Dec 09, 2020 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, thanks Grumble
floating-water
PostPosted: Mon Jan 25, 2021 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a different way to wire up buffers with guitar as opposed to synthesizer signals? I am having trouble getting this to work. I took a month off electronics so im a bit rusty. I've got a fuzz circuit and a delay circuit I am trying to blend, I only have TL072's
edit: i've got the fuzz coming through now but theres a constant hum that disappears when I cut power rail to the op amp. The sound is clean when its not connected to 9v?? The bias voltage is connected to pin 3 is that all thats required?
