Beginner sounds with Wren
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
Audio files: 299
PostPosted: Wed Mar 31, 2021 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
wakyct wrote:
interrupt input
heh, ok, added the following to the "currently working on" section of the Wren page:
2021-03-31 : Changed the help for some Envelope modules to explain the function of the inh(ibit) input.
oh, and also really did that - it will show up in a next release.
Then, to ensure a minimum gain, or a controllable range rather, you could use the Scaler or RangeConverter modules - the latter probably the easier one to use (both on the Ctrl1 tab).
Scaler uses a gain and an offset to control the range and the RangeConverter simply sets a minimum and a maximum value.
To understand how such modules work you can use the Value module (from the Utility tab).
wakyct
Audio files: 12
PostPosted: Sun Apr 11, 2021 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been enjoying trying out different combinations of sequencer modules, here is a basic one of Pattern and SeqRandom. Pattern makes it easy to play the rhythm by adjusting steps in small increments.
Modulating frequency and filter cutoffs by just a few semitones gives a nice buzzy sound.
pattern_on_seqrand_sinkdrumming.wren
 Filename:  pattern_on_seqrand_sinkdrumming.wren
 Filesize:  17.59 KB
 Downloaded:  388 Time(s)
sinkdrumming.mp3
 Filename:  sinkdrumming.mp3
 Filesize:  999.57 KB
 Downloaded:  480 Time(s)
Audio files: 299
PostPosted: Sun Apr 11, 2021 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
wakyct wrote:
nice buzzy sound.
Cool
wakyct
Audio files: 12
PostPosted: Sat Apr 24, 2021 9:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kind of realized anything can be a sequencer I guess, and in that spirit I recorded a sample from a tape of the Vienna Hofburgkapelle choir. Routed through a sample & hold and RangeConverter then quantized, it modulates the frequency. The LFO that triggers the S&H then also goes through a divider to inhibit the main voice's envelope and add some dynamics.
This makes me wonder in what ways a sample can control a patch in general.
gregorian_demake.wren
 Filename:  gregorian_demake.wren
 Filesize:  21.73 KB
 Downloaded:  430 Time(s)
gregorian_demake.mp3
 Filename:  gregorian_demake.mp3
 Filesize:  1.48 MB
 Downloaded:  479 Time(s)
John_W_Thompson
G2 patch files: 5
PostPosted: Wed Jan 26, 2022 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hope this is not offensive I tweaked the LFO freq and it sounded like an engine so I had to take it to it's logical conclusion. I am on day 1 of WREN; thanks for the snare patch it taught me a lot.
https://youtu.be/agKM7ffb6Zw
wakyct
Audio files: 12
PostPosted: Wed Jan 26, 2022 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not at all, I'm even YT famous now thanks to you Wink
John_W_Thompson
G2 patch files: 5
PostPosted: Thu Jan 27, 2022 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
ha!
