<on air> Various Artists March Equinox concert
Nord Modular Editor v2.10
Page 1 of 1 [5 Posts]
Endorfinity
PostPosted: Wed Jun 16, 2021 4:38 am    Post subject:  Nord Modular Editor v2.10 Reply with quote  Mark this post and the followings unread
Out of academic interest I'd like to install Editor v2.10 and compare it to v3.03.
Seems like I need to downgrade OS on my NM too.
Does anybody has older editor and OS? flower
Audio files: 309
PostPosted: Wed Jun 16, 2021 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
For windows?
Endorfinity
PostPosted: Wed Jun 16, 2021 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
For windows?
Yup. And thanks for quick reply Smile
Audio files: 309
PostPosted: Wed Jun 16, 2021 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go ... the zip holds two disk images (for the original two disks the software was distributed on), I think it will work when you copy all files into one directory and run the setup from there.
There is a readme file in Disk1.
I forgot how it worked with the OS .. I think it installs an OS uploader as well as an editor .. but as said .. too long ago to be sure :)
I've also added the factory default patches and the manual.
Good luck!
nm2_10.zip
NM Classic v2.10 disk images
 Filename:  nm2_10.zip
 Filesize:  1.65 MB
 Downloaded:  368 Time(s)
FactoryNM210.zip
Nord modular classic v2.10 factory patches
 Filename:  FactoryNM210.zip
 Filesize:  109.93 KB
 Downloaded:  369 Time(s)
nm2_1.pdf
Nord modular Classic v2.10 manual
 Filename:  nm2_1.pdf
 Filesize:  2.83 MB
 Downloaded:  359 Time(s)
Endorfinity
PostPosted: Wed Jun 16, 2021 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks Jan, much appreciated. You are legend! Smile
