Joined: Dec 11, 2010 Posts: 1029 Location: Toronto, Ontario - Canada
Posted: Wed Dec 07, 2016 7:22 am Post subject:
Yes, that should work. However, it looks like it is only in an SMD package. Also, it has a lower max voltage, so you need to be aware of that when designing your circuit. _________________ JacobWatters.com |
Joined: Apr 03, 2004 Posts: 24669 Location: The Netherlands, Enschede
Posted: Mon Jan 09, 2017 5:12 pm Post subject:
 _________________ Jan
gasboss775
Posted: Thu Jan 11, 2018 1:58 pm Post subject:
I really like the bass drum sound but still a bit unclear on its mechanics. 3.8H is a big inductor!
I'm thinking that the 3.8H inductor and 82n capacitor form a series tuned circuit, which in conjunction with the 4069 wired as an inverting amplifier, you get a tuned band pass filter with a centre frequency of:
Fc = 1/(2*pi*sqrt (L*C))
Fc = 1/(2×3.14×sqrt (3.8 × 82 × 10^(-9)))
Fc = 285 Hz approx which seems a wee bit high for a bass drum but the inductor probably has a huge tolerance so the figure could be at either side of this.
Now, I have a 500mH inductor which I believe are still made as spares for wah wah pedals.
Now to get the same Fo = 285 Hz, we need to rearrange the formula;
C = 1/ (2*pi*Fo)^2×L
C = 623.7 n , so probably use a 680n, though might be better with an even bigger cap for lower Fo, will try a 680n then maybe a 1u cap instead. |
IGR
Posted: Fri Jan 12, 2018 4:47 am Post subject:
| You are near right, but.. Original LC has damping factor approx. 0.00734 and bandwith of 4,2 Hz. Yours will have damping factor 0.05 /bw 31,83 Hz. It will not so readilly oscillate as you need. |
IGR
Posted: Fri Jan 12, 2018 5:03 am Post subject:
I just thought try small power transformer primary, this should be about 5H.
Check Roland TR 77 schematic too, there is 16H inductance in BD tank, of course LC circuit in parallel. Good luck. |
gasboss775
Posted: Fri Jan 12, 2018 5:51 am Post subject:
IGR I did wonder about this, though I was thinking in terms of Q ( resonance ) only because I am more familiar with that concept.
The mains transformer primary might be worth a try, thanks for the suggestion. |
IGR
Posted: Fri Jan 12, 2018 6:10 am Post subject:
| I just breadborded this circuit- primary 3W mains transformer in parallel with 1uF cap, excited by piezo pickup. I got simple passive stompbox, much better then all those cigarbox with piezo. It must be followed by high impedance preamp, otherwise nice boom disappears. |
gasboss775
Posted: Fri Jan 12, 2018 10:54 am Post subject:
I'm going to experiment with this over the weekend, I like the idea of using inductors in music circuits, they are quite unique and quirky.
Craig Anderton made a passive filter using one half of a transformer a bank of capacitors selected by a rotary switch and a pot to vary the resonance.
The CR78 drum machine had a few inductor based percussion voices and I think a lot of these early beat boxes used LC circuits in their percussion voices. |
IGR
Posted: Fri Jan 12, 2018 11:09 am Post subject:
| I agree, inductors are piece of magic, partly unpredictable, hard exactly reproductible due core alchemy. |
Posted: Sat Jan 20, 2018 9:10 pm Post subject:
I am glad to see that people are still playing with this idea.
I used those huge conductors only because I had them. I had just taken apart an old EQ that was filled with them. They are big things about 1" in diameter.
You should be able to replace the LC parts with RC instead and get the same sound. _________________ JacobWatters.com |
blakeAlbion
Joined: Jun 16, 2020 Posts: 25 Location: Boston, Massachusetts, USA
Posted: Fri Sep 10, 2021 11:36 am Post subject:
| I am very interested in this topic. Where does one buy inductors similar to those in pre-1980 drum machines? |
blakeAlbion
blakeAlbion
Posted: Fri Sep 10, 2021 11:51 am Post subject:
| Uh... but some of these inductors are like 4H, 7H, 15H. Yow. I guess I could build the circuit and then wind me an inductor with some wire and keep wrapping until it sounds good. |
Steveg
Joined: Apr 23, 2015 Posts: 184 Location: Perth, Australia
blakeAlbion
Posted: Fri Sep 10, 2021 6:14 pm Post subject:
| Thanks! I saw Mouser has a number of larger inductors, but wow they are big and heavy and high-current. I’m putting this project off for a bit, but I have this Hammond Rhythm box with the rhythm logic, but the voice box is missing. Sigh. So I will circle around to this topic sometime this winter. I will try my hand at transistor-based analog drums. |
Steveg
Posted: Fri Sep 10, 2021 6:27 pm Post subject:
Jurgen Haible made a version of the 914 using simulated inductors instead of iron and wire but he used a complex circuit. A simpler gyrator design can be found here: https://sound-au.com/articles/gyrator-filters.htm
The Moog filter uses inductors to ground so gyrators should work perfectly. |
Posted: Fri Oct 15, 2021 10:17 am Post subject:
I don't think you need to use inductors. I was just playing around with them because I had some I took out of an old EQ. They are being used as low pass filters, so you can just use a resistor and capacitor instead. _________________ JacobWatters.com |
