please delete
Page 1 of 1 [5 Posts]
vladosh
Audio files: 51
PostPosted: Sun Apr 04, 2021 4:50 am    Post subject: please delete Reply with quote  Mark this post and the followings unread
vladosh
Audio files: 51
PostPosted: Sun Apr 04, 2021 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
cslammy
PostPosted: Wed Oct 13, 2021 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, can you provide a schematic?
Interesting because SEMs used 3080 OTAs for the heavy lifting; to do that discreetly is doable but you'd have to very carefully match the transistors.
What program did you use to lay this out? Kicad?
vladosh
Audio files: 51
PostPosted: Wed Oct 13, 2021 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
cslammy
PostPosted: Wed Oct 13, 2021 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
drawn for BCMXXX matched tansistofs
if you build it share how it sounds Smile
I have not seen BCM matched transistors before thanks!
Very cool!
https://www.mouser.com/datasheet/2/916/BCM56DS-1598793.pdf
