Derop
ixtern
Posted: Sun Oct 17, 2021 3:35 am Post subject:
For me the hardest thing was to find pins 4 and 5 on MIDI socket - pinout is from the front or from behind? So attaching properly labelled pinout.
I had used some different values for 6N138 but as it not worked reliable for me (maybe because I'd not used Schmitt triggers), I had switched to 6N137.
Here is my schematic with 6N137 which I've used in two synthesizers so far.
23.26 KB |
| Viewed: |
4567 Time(s) |
200.26 KB |
| Viewed: |
4566 Time(s) |
106.25 KB |
| Viewed: |
317 Time(s) |
Derop
Posted: Sun Oct 17, 2021 7:03 am Post subject:
| Thank you so much for your reply! In fact... from what you are saying.. i must had soldered the 4 and 5 pins incorrectly. I will try changing them and update the topic |
Derop
Posted: Sun Oct 17, 2021 9:11 am Post subject:
| ixtern wrote: | For me the hardest thing was to find pins 4 and 5 on MIDI socket - pinout is from the front or from behind? So attaching properly labelled pinout.
Here is my schematic with 6N137 which I've used in two synthesizers so far. |
And yes!!! you were 100% right, pins 4 and 5 soldered incorrectly . It solved all my issues. It works perfectly now. Iam sooo grateful!!! Thank you so much! |
Posted: Sun Oct 17, 2021 1:09 pm Post subject:
I have lowered the resistor designated as R101 in your schematic to 68 ohm and put an LED in series with that resistor so I have an indicator if the midi is coming in. _________________ my synth |
ixtern
Posted: Mon Oct 18, 2021 1:11 am Post subject:
| Grumble wrote: |
I have lowered the resistor designated as R101 in your schematic to 68 ohm and put an LED in series with that resistor so I have an indicator if the midi is coming in. |
Clever solution. But I prefer more predictable design, like in my second schematic - separate LED drivers after optocouplers. |
