pixels & scanlines
Page 2 of 2 [30 Posts]
Goto page: Previous 1, 2
PostPosted: Mon Jun 06, 2022 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
and some more photos,..
 Filesize:  240.57 KB
 Viewed:  239 Time(s)
 Filesize:  418.51 KB
 Viewed:  254 Time(s)
 Filesize:  415.24 KB
 Viewed:  234 Time(s)
 Filesize:  391.66 KB
 Viewed:  236 Time(s)
 Filesize:  286.38 KB
 Viewed:  232 Time(s)
PostPosted: Sun Jun 12, 2022 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You can see it in action in the following video: https://youtu.be/tjxw84iRoFg
also still on twitch which probably has better quality https://www.twitch.tv/videos/1501105860
This was a test between the capture method I have been using (cheap composite to HDMI upscaler/converter
+ generic HDMI capture device) on the left and a more expensive Elgato Video Capture device on the right.
All the music I played was created by Muied Lumens and can be found here
PostPosted: Fri Jul 15, 2022 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
recent video feedback experiments, using video mixers, color corrector and a camera + CRT.
I got the camera setup a little bit better but I think it just doesn't really have a suitable lens.
It does give a nice spherical effect though.
https://youtu.be/c0K8GSeX56k
or the cropped and resized 4:3 version
https://youtu.be/BFfJSkS02Yg
all music by Muied Lumens (see video description for more info).
Psyingo
PostPosted: Sun Jan 22, 2023 11:59 am    Post subject: Original Sima Edit 2 Schem Reply with quote  Mark this post and the followings unread
Could you post the original (unmodified) schematic for the Sima Edit 2? I believe the enhance might come from the section on the main board? the section that looks similar to the AVE doesnt have a cap on the emitter of the pnp, so it's actually just functioning as an amplifier without high frequency boost.
PostPosted: Sun Jan 22, 2023 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is what I got, can't promise it's 100% correct.
'Video Enhancer" connects to the pot of the other schematic.
 Filesize:  77.48 KB
 Viewed:  232 Time(s)
