 Forum index » Online Music » The sound library
Bass Guitar (Jay Turser)
Page 1 of 1 [3 Posts]
Airlock
Audio files: 53
PostPosted: Sun May 28, 2023 7:51 pm    Post subject: Bass Guitar (Jay Turser)
Subject description: Jay Turser semi-hollow all notes E1 to E4
(This is a test post and zipped attachment, please advise of anything that could be improved.)
Zipped folder containing 37 48kHz/24 bit wavs of the notes from E1 to E4 of a Jay Turser short scale semi-hollow bass strung with flatwound strings, with the passive tone controls wide open, no compression or EQ. Not normalized, all the files are the same length but sustain and level vary quite a bit on this instrument. I suspect the lowest octave will be most useful to folks.
Oh, and all notes were thumb plucked. Because the thumb is thumpier that any other other body part you might care to try to play bass with. Don't ask me how I know.
Jay Turser Notes.zip
 Filename:  Jay Turser Notes.zip
 Filesize:  16.28 MB
 Downloaded:  190 Time(s)
Audio files: 500
PostPosted: Tue May 30, 2023 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
These are great! And they arrived just in time for a Microfreak update which adds sample playback ability - brilliant timing.
If you have more, keep them coming. Very Happy
The only comment I have is that they're a bit soft. They're 24 bit so there's no issue with batch normalizing them but you wanted some feedback so... Wink
Airlock
Audio files: 53
PostPosted: Wed May 31, 2023 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob, I need the feedback. I recorded straight into an RME UFX and thought it was a bit soft (but usable) on that bass myself. The idea was to not use any help (EQ/compression) or pre amps (I HAVE some pres) and let the end user do what they wanted on the sound of the instrument.That is the cheapest bass I own, strung with flatwounds, and is the kind of thing that a lot of British Invasion bands were using (Framus, Hofner etc.) I chould have pumped up the gain on the interface, but I don't want to clip. Anyway, it's good to know that putting the files up there in that way (individual file per note etc) is the appropriate way to go about things.
Up next up is my '73 Hagstrom Swede bass (my gigging bass back then) which does have a hotter output and a LOT more sustain. Which raises a question: when is a note too long? The open E on the Swede I just recorded has usable sound for about 17 seconds, which might be excessive. Where should I cut it off- if at all?
Again, thanks for the feedback!
