today> Twyndyllyngs Chez Mosc
What can i do with cd4050 ?
Page 1 of 1 [12 Posts]
jean bender
PostPosted: Tue Mar 27, 2012 3:31 am    Post subject: What can i do with cd4050 ? Reply with quote  Mark this post and the followings unread
Hi !
i've found a huge stock of cmos stuff ( cd4029, 4072, 4012, 4075, 4025, and 4050).
I'll try to make something with the logic gates, but i've no idea how to use cd4050, and this unit doesn't seem to be an often used one..
Thanks for your support ! Wink
http://h.a.k.free.fr/
www.electroncanon.org
JingleJoe
PostPosted: Tue Mar 27, 2012 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
This 4050?
http://www.alldatasheet.com/datasheet-pdf/pdf/50859/FAIRCHILD/CD4050.html
It's really boring, sorry to break it to you Sad It's probably not used much for that reason.
however combined with the filter/synth drum thing described in this recent thread: http://electro-music.com/forum/topic-52786.html you may get some interesting bloops and bleeps, but by itself this chip doesn't do anything very musical.
jean bender
PostPosted: Tue Mar 27, 2012 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, it's this unit... Pff, i have 90 of them, and i don't know what i'll do with it. I can't eitherway understand for what they have been produced, so... I won't throw them, maybe one day i'll get it...
Well, i've got 500 cd4029, hope i'll be luckier !
mrmrshoes
PostPosted: Tue Mar 27, 2012 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
you can use the 4049 as a gain stage.
if the 4050 works in the same way (??????) you can make Mixers, pre-amps, analog 2 digital converters and distortions.
check out NicK Collins book for 4049 examples.
http://www.nicolascollins.com/texts/originalhackingmanual.pdf
jean bender
PostPosted: Tue Mar 27, 2012 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, i know, but as 4050 doesn't invert, i don't think it'll be ok for mixer or osc... Evil or Very Mad
JingleJoe
PostPosted: Tue Mar 27, 2012 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stick 'em on ebay for 20p each!
Gah, I didn;t notice they were non-inverting Confused they really are quite bland.
As for thier original purpose I suppose it would be to improve fan out.
richardc64
Audio files: 26
PostPosted: Tue Mar 27, 2012 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right, it can't have gain. What it does do is convert logic levels. The input voltage can be higher than Vcc. So you could interface 5V logic with anything up to 15V.
The 4049 does the same, but also inverts.
skifflefella
PostPosted: Mon Jul 31, 2023 12:00 pm    Post subject: I am going to experiment with 4050 as a buffer, and multiple Reply with quote  Mark this post and the followings unread
Very late reply. I have a couple on the way. I have been after buffers for my growing lunetta modular for a while, especially to build buffered multiples. Hopefully this will work out well. They are dull, but dull can be useful - maybe
okelk
PostPosted: Wed Aug 02, 2023 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
...well...I wouldn't say that they are useless...but I can't think of any way to misuse the in a useful way...
They can sink more current than most 4000 series chips so they can be useful as LED drivers.
Or you can use them as High-to-Low logic level converters. For instance if you want to use some 5V chips in a 9V or 12V lunetta (there are other ways tpo do that thogh)
ianbax
PostPosted: Tue Sep 19, 2023 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Seen as this topic floated to the top - I've used 4050s a few times
I had this weird thing where my 4093 based clock would change tempo when I patched it (never really got to the bottom of it but assumed I was loading down the output somehow), I put a 4050 buffer on the outputs and it sorted the problem - without inverting the signal (a transistor might have sufficed but I had 4 outputs from the 4093 so made sense to use an IC for neatness)
At some point I'm planning to make a utility module with a lunetta version of a 'buffered mult' so if a clock signal is being split and sent to several places it takes advantage of the 4050s better fan-out.
I think it can't be used to replace 4049/4069 in filters etc as there's no 4050UB unbuffered version.
They can be used an a LED driver although I haven't found that necessary. Interesting vid here: https://www.youtube.com/watch?v=_spbp3Kyfd4
okelk
PostPosted: Tue Sep 19, 2023 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
...also, it's non inverting. using a gate as an amplifier always needs negative feedback.
cool!
zaphod betamax
PostPosted: Thu Oct 05, 2023 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I bought a bunch of 4050 buffers but the pinout is so whack
