 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Kurzweil Midiboard help
Page 1 of 1 [2 Posts]
funktapu55
PostPosted: Mon Sep 15, 2025 9:15 am    Post subject: Kurzweil Midiboard help
Subject description: Whole keyboard not working
Hello I recently got myself a Kurzweil midiboard. After running the diagnostic test I found The key bed was Not transmitting any data couple of sliders not functioning. I repaired those now everything on the slider and switch panel Works Even the mod and pitch bend wheel will change the sound of a keyboard Plugged into it but there is no sign of life from the keybed. If anyone knows what best avenue to troubleshoot this issue please let me know
Thank you
George
PostPosted: Wed Sep 24, 2025 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Start by checking to confirm that the cables to the keybed are properly seated.
What is the model? Maybe there is a setting that needs to be changed.
Also, are you checking all channels? Maybe it is sending out on a different Midi channel.
JacobWatters.com
