newbee: want to start with building a 'function generator'
Page 1 of 1 [8 Posts]
comfused
PostPosted: Thu Nov 24, 2005 8:59 am    Post subject: newbee: want to start with building a 'function generator' Reply with quote  Mark this post and the followings unread
hi,
I'm new to the forum and new to the DIY Wink
I just finished my first guitar stomp box - and it's working
I'd like to give the SoundLab a shot
but I think it's better I first try to build a 'function generator'
but I can't find a stripboard layout anywere
anybody have an idea where to look ?
thanks in advance,
Tim
PostPosted: Thu Nov 24, 2005 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim! welcome to electro-music.com!
you could start with this;
http://www.musicfromouterspace.com/analogsynth/YOUR_FIRST_SYNTH/YOUR_FIRST_SYNTH.html#STRIPBOARD
The stripboard version is at the bottom of the page.
Then get your ass over to the sound lab section here Smile
Get talking to the Zebra or Uncle K- they are your ship captains Wink
Tom (part time caretaker:D )
comfused
PostPosted: Thu Nov 24, 2005 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply Tom
I was planning to take a shot at the SoundLab
but since I think it might be just a bit to hard for me
I was planning to start with building just a simple sound-device
and when I understand how that works - I'll start with the SoundLab
dnny
PostPosted: Fri Nov 25, 2005 4:11 am    Post subject: Re: newbee: want to start with building a 'function generato Reply with quote  Mark this post and the followings unread
Hi Tim and welcome.
isin´t "function generator" just a oscillator whit multiple wave shape outputs ?
well then i advise you to start whit this VCO (Voltage Controlled Oscillator)
it´s not on stripboard but it has PCB-layout and if you are going to advance and build Sound Lab, then you would know how to make those PCB´s. and you could hook the VCO whit your Sound Lab...
but for a starter i would recommend the WSG (Wierd Sound Generator) as v-un-v did. it´s easy and fast to build and its just great
and for PCB making read this thread :
easy PCB making
daniel
PostPosted: Fri Nov 25, 2005 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
Any which way you decide to go should be fine.
The Soundlab is actually not as hard as it looks.
Remember, building the board (either PCB or Stripboard) is less than half the job. The thing which I recommend you put some thought into is the box you put it in. Mounting and wiring all the front panel bits is a big job, and the place you're most likely to make a mistake. Planning this bit will make everything else much smoother. Check out the front panel designs on Ray's site. Print some off (clear stick on bubble jet sheet is a handy thing!) and get to know where's what before you do anything else.
If you have any hassles at all, just post a question on here. I think I speak for all the usual suspects when I say we'll be glad to help out.
PostPosted: Fri Nov 25, 2005 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
oops- I forgot dnny! He's our Alchemist and Sorcerer! Shocked Cool
ACHTUNG!
comfused
PostPosted: Fri Nov 25, 2005 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the replies so for
so I'm staring at the StripBoard Lay-out (http://www.musicfromouterspace.com/analogsynth/YOUR_FIRST_SYNTH/YOUR_FIRST_SYNTH.html)
and looking over the components lists (Andrew Sharp)
but seems the potmeters aren't in the list
anything else that's missing from that list ?
PostPosted: Fri Nov 25, 2005 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tim,
sorry I left the pots off that list, mainly because it's just to clarify the identifiers for the stripboard layout. Everything else is there. So, off board you'll need to add 7*1M pots, 2*100K pots, & 2 spst switches.
