 Forum index » Clavia Nord Modular » Wish List
Reverb and delay modules with variable sample rates
Page 1 of 1 [4 Posts]
Essential
46%
 46%  [ 7 ]
Nice to have
40%
 40%  [ 6 ]
Not needed
13%
 13%  [ 2 ]
Total Votes : 15
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Dec 02, 2005 10:31 am    Post subject: Reverb and delay modules with variable sample rates Reply with quote  Mark this post and the followings unread
Imagine having a dropdown combo to pick the sample rates (on delay and reverb modules). Now we have longer delay lines & use less RAM ...
/Dasz
Acidfever
PostPosted: Tue Dec 06, 2005 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering........if Clavia changed the way the digitizer module works maybe they could make it so that the delays and reverbs actually set their bitrate and samplerate from the incoming signal.
So if you set the digitizer to 48 Hkz the Delays and Reverbs automaticly switch to 48Khz aswell.
Problem is this would need changes in de digitizer module since both the sample rate as quantization module don't have the needed values at the moment.
jksuperstar
G2 patch files: 18
PostPosted: Wed Dec 07, 2005 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would take more than a change to the digitizer module. It would involve changing the base DSP operating system, since that's where the 96kHz sample rate is defined. The input & output of the digitizer module are always at 96kHz (a "new" sample is present every 96kHz when a red input is used), but the values allowed through are downsampled to something that resembles something lower.
Make sense?
Rob
G2 patch files: 109
PostPosted: Wed Dec 07, 2005 8:32 pm    Post subject: Re: Reverb and delay modules with variable sample rates Reply with quote  Mark this post and the followings unread
/Dasz
Should be a jiffy. Some smoothing and scaling of the modulation input to the set static delay time would also be a very useful addition. I find this much more annoying as longer delay times.
/Rob
