 Forum index » News... » Gear News
Alesis mixers with Firewire
Page 2 of 2 [46 Posts]
Goto page: Previous 1, 2
PostPosted: Fri Jan 06, 2006 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
Oddly, I know there is a lot a talk around here about DACs sounding bad and certain preamps are better than others and budgut mixers aren't very good - but to me, the most problems I've had are with bad connectors and bad cables. Even good 1/4" phone plugs start crackling over time because of dirt and corrosion. A patch bay just puts more connectors in the signal path. If you can get by without that, why not.
Maintenance! You will have to service your Moog Modulars, your patchbays, the pots in your mixers.. the lot.
Decent patchbays, good cables and a balanced signal path all the way to the DAW inputs will do the job. This is the preferred way of doing this in pro studios anyway.. no matter if you have a fancy high end console or not.
Obviously few synths have a balanced output. This can be mended by getting a DI / balanced line driver. Speaking of budget gear, Behringer has a 1U rack thingie which isn´t really that bad. Check out the DI-800
This product is NOT built like a tank. It is in fact rather fragile, but not as fragile as the UB mixers. The audio quality is quite acceptable. It is in fact better than one of my old JBL branded boxes. It works great with synths.
There are better products out there, but having one of these around is not a bad idea anyway. The US street price is approx. 75-85 USD.
This is however a fairly inexpensive active design. A high end active DI with the "same" specs will easily cost 15-30 times more. Mind you, those aren´t soundwise 15-30 times "better"... but they are still worth it.
It is also cool to have DIs and linedrivers with transformers.
Flickr
lamarcph
G2 patch files: 4
PostPosted: Fri Jan 06, 2006 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll wait a bit, then i'll probably go for something like the Motu 828 or the
Mackie 400F. This last one seems nice.
I'll have to collect some more pennies first.
PostPosted: Fri Jan 06, 2006 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know this is not what you want to hear... but.. why not collect more money and get a secondhand M-Audio 1010.. NOT the LT version. It is quite good still.
Flickr
lamarcph
G2 patch files: 4
PostPosted: Fri Jan 06, 2006 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's seems that the m-audio delta 1010 is less expensive than the Mackie 400f.
What would be the advantage of the 1010 over the 400f?
Also, unless there is an adapter, my laptop doesn't have a pci interface.
I had a bad experience with m-audio, with the Audiophile. I know it's the low line, but my driver was really unstable. I tried it with 3 differents computer.
Maybe I am looking at the wrong m-audio 1010.
PostPosted: Fri Jan 06, 2006 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, if you have a laptop, then forget about the 1010.
It is a PCI card with a breakout box. It isn´t really "better" that the 400F in any way, but it isn´t bad either. It has no microphone preamps though.
I am sorry that you have had problems with the drivers for the Audiophile 2496 PCI card. The card itself is quite good. The audio quality is absolutely OK.
Another option is the M-Audio 1814. This is a very capable interface. The drivers are quite decent on OS X. I know nothing about how the 1814 PC drivers perform. I have been told they are excellent. I reckon you can get this for 40-50% less than the 400F. The 1814 has ADAT input which is a great way to add more channels. the 400F doesn´t have that, but it does on the other hand allow daisychaining. My guess is however that if you need twice the numbet of inputs then 2 400F interfaces won´t be your first choice anyway.
Re drivers, keep in mind that almost none of the pro/semipro audiointerfaces will work well with games and stuff like that. If you need sound for games then any of the better games oriented consumer sound cards will be a far better choice. This "problem" is however a PC thing. This is never a problem on OS X.
If we are talking just about audio quality, then I would suggest the Echo Firewire interface. It isn´t insanely better than the 1814 or the 400F.. but.. there is really something about that one. I would choose the Echo FW device for acoustic recordings and stuff like that.
Anyways, in your case I would consider the M-Audio 1814.
Flickr
lamarcph
G2 patch files: 4
PostPosted: Fri Jan 06, 2006 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
The big advantage I saw with the 400F is the ability to use it as a mixer when the computer isn't around. from what I can read on the manual, the m-audio 1814 doesn't seems to offer that possibility. Does all those units (m-audio 1814 and echo audiofire) offer that possibility?
On paper, for 100$ more the 400f offer the 192khz all around, and 4 mic preamp. they are apparently good. (Craig Anderton raved about them on a 20 pages review)
My drivers problems is with the Audiophile usb. At some point it just stop. My first midi keyboard was also a m-audio. a radium61... and it wasn't love at first site. ok ok, I am not that young but I was "born" on an acoustic piano. I tend to think about m-audio as gray plastic things... i may be wrong.
elektro80, I really appreciate your help. Last year you gave me some monitor and suggested Yamaha mp5a that I still have and really like.
PostPosted: Sat Jan 07, 2006 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
It is very nice to hear you like your MSP5 monitors!
You made a good point re the mixer in the 400F. The M-Audio interfaces do have a software mixer, but it simply won´t work with the computer disconnected. It might very well be that the 400F is what you should get. It is a good product.
To me it seems that mac users have a whole different view on the M-Audio drivers. On OS X most M-Audio gear is quite good. They did a serious mess of some Firewire 410 drivers though, but those are solid now. At last.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jan 07, 2006 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah Exclamation my 1814 works flawlewssly Very Happy
my MSP5 too Wink
Audio files: 232
PostPosted: Sat Jan 07, 2006 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the MOTU 828MK2, something to consider too. I think the internal mixer is a BIG feature. Not only can you use it when you aren't connected to the computer, but it takes a big load off of the computer when you are connected. Also, you get virtually zero latency monitoring.
I'm not convinced that 192 KHz sampling is necessary. It uses a lot of computing resources.
The MOTU computer mixer application doesn't respond to MIDI, too bad. I just checked the Mackie manual - it dosen't either. Sad
PostPosted: Sat Jan 07, 2006 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
True!
That said, most of the new interfaces all have the new trendy high samplingrates. It sure is a selling point but the actual uselfulness is another matter altogether. Using 88.2 khz at 24 bit is obviously quite nice when you have to capture something acoustic and then process it a lot before slamming it down to 44.1khz24bit. As for 96khz and higher, well..
Only thing one can hope for ( and it is in fact true in some cases ) is that many of these new interfaces are using new and modern components that will handle 44.1 -> 88.2khz "better" than old gear. And it is not only about components. A lot of these interfaces are more or less the same, but with a slightly different feature set. There are however a few that designed slightly unlike the others like Echo and RME interfaces .. Interesting gear.
Audio files: 232
PostPosted: Sat Jan 07, 2006 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember when 16 bit 44.1 stereo interfaces for VAX computers costed $27,000 US. That was in the mid 80s. What a difference 25 years makes.
lamarcph
G2 patch files: 4
PostPosted: Sat Jan 07, 2006 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried to record yesterday with my m-audio. My daw software was running the midi clock and I wasn't able to get a good midi clock from the Audiophile usb. It was worst than bad, sometime it would stop for a few second and then start again... I tried both on the G2 and on the Evolver, with different midi cable but it just didn't work. And if I would plug one synth in the other, it would be constant... like a clock...
It's true that for audio quality, the Audiophile USB is quite good. The latency is not bad either, but... for multiple take recording, it just won't work, every thing is always out of sync.
i know that computer have trouble sending a constant midi clock, but I hope that those higher grade sound device will be able to send a usable midi clock...
Audio files: 232
PostPosted: Sat Jan 07, 2006 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, just to be clear, the interface doens't generate a clock, it just transports the clock from the synth to the computer. You should expect the computer sequencer to follow the G2's MIDI clock. Maybe there is a problem with the interface you have.
Make sure you have not other USB devices connected to the computer's USB ports. They may be sending signals that interrupt the device. Firewire is a point-to-point connection, so that is a bit less of a problem with those.
lamarcph
G2 patch files: 4
PostPosted: Sat Jan 07, 2006 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I probably misled you. The synths were slave. The computer (the audiophile usb) was the master.
My daw software (tracktion 2), can't be a midi clock slave apparently. It can only follow midi timecode.
So my computer was the master and the synths were slave.
Audio files: 232
PostPosted: Sat Jan 07, 2006 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, that's different - very different. Software devices are generally quite poor at sending out stable MIDI clocks. I guess it is possible, but I've only heard of people having problems with it. Even when you are using only hardware, it takes some experimentation to figure out what piece of gear to use as the master clock source. The computer is usually the least effective.
This was not always the case. In the early days of MIDI, there were smart MIDI interfaces made by Voyetra and others that contained their own clocks. With those, computers could generate very stable clocks. But those MPU 401s are unfortuantely long gone. You can use them with modern software, but not in "smart" mode.
If Tracktion 2 can't run is slave mode, you may consider getting something that can. I'm surprised to hear that though. You may want to check there user forum to verify.
PostPosted: Sat Jan 07, 2006 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK.. this is midi. Shocked
I have been meddling some with midi. I even bought an MSQ 700 in 84.. or was it 85? I even have the MMT-8 ( 87? ). Anyways, I would trust mosc and Carlo and the lot for that MIDI troubleshooting... but not me..
But.. one thing.. some of the M-Audio drivers have had midi bugs. Check out M-Audio´s site. The FW-410 had some serious issues way back. I am mostly using a Steinberg Midex-8. I kinda gave up on the M-Audio built in midi interfaces in the FW and Audiophile products.
Audio files: 308
PostPosted: Sat Jan 07, 2006 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well yes, that's sort of funny. The smart mode was not really needed in the early days. I'v always found it easier to just take over the timer interrupt, make it go faster, and do timing critical stuff from there. A practice that was no longer possible on later 486 chips (with DOS 5 or 6 and later 486s interrupts got virtualized away). Unfortunately at that same time the smart mode disappeared from MIDI interfaces - just when they were needed.
PostPosted: Sat Jan 07, 2006 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Truth be told, 192 is a hot one at times. Handling it well is another matter altogether though.
One point to make is that some of the 192khz heads are way into using analog outboard processing.
Flickr
Audio files: 232
PostPosted: Sat Jan 07, 2006 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only theoretical reason to use 192 is if you want to do a lot of digital non-linear processing. You might get less noticable aliasing than if you did that at 44.1 KHz. But no, they use external analog processors. Shocked
Reminds me of story. A non-technical friend was buying an amplifier for his strereo. He asked me for a recommendation. I found something good and cheap. At the time it was a Dynaco, they were excellent. Anyway, he went to the store and came back with a rather expensive boutique brand. I asked him why.
He said he got a good deal. The Dynaco costed $200. It had 0.05% THD. The one he bought was $400 but it had 0.01% THD. He got an amp that was 5 times as good for only twice the money! Rolling Eyes
192 is four times better than 44.1, isn't it? Laughing
PostPosted: Sun Jan 08, 2006 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite right.
You know, the DAWs, the computers and the DAW plugins aren´t quite there yet. Using 192 khhz samplerate is one messy affair.
Flickr
Laughing
Flickr
