problem -- strange clicks on modular
Page 1 of 1 [4 Posts]
CJ MMx
PostPosted: Sun Jan 22, 2006 7:45 pm    Post subject:  problem -- strange clicks on modular Reply with quote  Mark this post and the followings unread
hi! last days i was playing with my synth in multitimbral mode and when i downloaded pads patch into slot D i've heard strange clicks instead os the sound. first i thought that i exhausted the voice limit. then i stopped the sequencer and switched only slot D. but there were still that low volume clicks. i've opened the editor and looked at the patch structure. there were used CVA with a chorus module in it. in PVA the was a stereo output routed to CVA. when i routed it to outs 1/2 the sound appeared. after that i discovered very strange thing. when i used left channel from PVA -> CVA there were strange clicks. with right channel everything is OK. and this shit appears only in slot D but not on all patches that use CVA. who know why it happens and who had the same problem?
PS: sorry for my english
superWarm_Spectral_Pad.pch
pads patch
 Filename:  superWarm_Spectral_Pad.pch
 Filesize:  3.59 KB
 Downloaded:  286 Time(s)
Dark Psychedelic Emotions
Audio files: 297
PostPosted: Mon Jan 23, 2006 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
The NM Classic does indeed have a slot D bug that makes nasty sounds under certain conditions.
Mantra
PostPosted: Mon Jan 23, 2006 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it known what causes this bug?? Since it sounds random it would be nice if there would be any information of what to do to avoid these problems.
Audio files: 297
PostPosted: Mon Jan 23, 2006 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't quite remember it, but googling on "nord modular "slot d" bug" (without the outer quotes) will give some hinting hits.
