Control micro settings via nord lead 2 knobs
Page 1 of 1 [3 Posts]
Shinobi
PostPosted: Mon Feb 27, 2006 3:34 pm    Post subject: Control micro settings via nord lead 2 knobs
Subject description: is it possible?
Hi all, a friend of mine has just bought a micro so i wanted to try it out..
i got a nord lead 2 so my question : is it possible to assign knobs on the micro editor to the nord lead 2' knobs? (so use the nord lead as a simple midi controller in this case)
if yes how to do it?
thank u very much
PostPosted: Mon Feb 27, 2006 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should be possible.
In http://www.clavia.se/nordlead/Files/NordLeadV2_XManual.PDF you can find the MIDI CC codes sent out by the Nord Lead (chapter 12).
For the μModular you can (in the editor program) right click on a knob to assign a MIDI CC to it, it will then listen to that CC (and it will send it as well when a physical knob that is mapped to it as well is turned).
In the synth settings for both synths you should check that they use the same MIDI channel.
Shinobi
PostPosted: Mon Feb 27, 2006 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
great!
thank u very much Blue Hell Very Happy
